Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
Reload this Page >
Settings to tame a Trex 450 ?
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 06-23-2009, 03:45 PM
CostaRica1
Default Settings to tame a Trex 450 ?
I need to calm down a little my 450 sa...besides the flybar weights is there some settings I could apply on my DX6i to make it more friendly? Thanks in advance !
Old 06-23-2009, 04:56 PM
Rafael23cc
Rafael23cc's Avatar
Default RE: Settings to tame a Trex 450 ?
1. Use exponential on the cyclic functions
2. Bring the head speed down
Rafael
Old 06-23-2009, 05:14 PM
Burntt32
Expo is amazing, i didnt used to fly with it until just recently. start around 25 or 35%
Old 06-23-2009, 06:07 PM
CostaRica1
Details please........[]
Old 06-23-2009, 06:45 PM
ace22459
I have a DX7 so programming is probably about the same for the DX6i. Bring up the dual rates/expo screen. Select aileron and then dail in about +30% and leave dual rates at 100%. Do the same with elevator. I also use +30% on the rudder. This "softens" the servo response around midstick. In other words, the servo doesn't move as fast but you still have the full range of movement. You can experiment with the expo percentage. You may want more or less. Just remember that Spectrum and JR radios use positive expo to soften things and negative to make it more responsive. Other radio brands like Futaba use opposite values for expo. I wouldn't lower the headspeed. It won't be as stable.
Old 06-23-2009, 07:59 PM
Rafael23cc
Rafael23cc's Avatar
ORIGINAL: CostaRica1
Look in page 109 of your DX6i manual. As it says there, + numbers soften the "feel" around the center of the stick and still give you the total travel programmed on the radio. a - number makes the "feel" more sensitive.
[link]http://www.spektrumrc.com/ProdInfo/Files/SPM6600_DX6i_Manual-LoRes.pdf[/link]
Rafael
Old 06-24-2009, 10:04 AM
Steve Collins
My Feedback: (8)
I believe there is an article on how to do this on Trextuning.com.
http://www.trextuning.com/flybarweights.php
