RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   T-Rex heli (http://www.rcuniverse.com/forum/t-rex-heli-435/)
-   -   Flybarless system or not? (http://www.rcuniverse.com/forum/t-rex-heli-435/11194971-flybarless-system-not.html)
k5nwz 08-15-2012 04:11 PM
Im somwhat of a newbie and at this point just wanting to master controled forward flight with a Trex 450 I just bought.. If all im really wanting to do is practice "non 3D" is there any benifit to having the flybarless system? and what about the 3 axis gyro? will that help me?
<br type="_moz" />
ACE_ 08-15-2012 04:47 PM
RE: Flybarless system or not?
I have a Sookum 360 and yes they work. But be warned it not something you just plug in an go. They are complicated to set up, the instructions are clear and pretty easy but you will need a good understanding of the Bell and Hiller set up of a helicopter. The Skookum hooks up to my computer and everything is set up in a software program you get on line. I liked mine when I had it installed in my T-Rex 450, also still have my EXI four blade rotor but I got rid of all my 450's (moved up into Nitro's). I do still have my Blade 400 and am planning on installing everything into a UH-60 Blackhawk fuselage this winter.
Read up on all of the control settings for your specific heli, make certain it's all set up properly,  follow your Gyro instructions and you should do ok.</p>
ahamay 08-15-2012 04:54 PM
Quote:
ORIGINAL: k5nwz
I don't see the point of converting a heli you have just bought to fbl, you should have just bought an fbl heli to start with in that case. I would stick with the flybar untill you can hover and fly circuits in all directions at a minimum before going fbl, especially since you have already invested in the flybar.
k5nwz 08-15-2012 05:01 PM
Thats what I was hoping for. I would be willing to invest if it will help me learn to fly it but if not, I will just leave it alone and puit it inot the next bird. Now to find someone to make sure its set up right before I try to fly it...lol
Solman 08-18-2012 11:04 PM
I personally think you should just stick with the fb system. It is more simple to work with. In some ways fbl helps, but in other ways it doesn't. It is nice because you never touch the trim, but at the same time, when it goes off at an angle, it doesn't self correct like a flybar does. So they each have their advantage, but I wouldn't waste time and money into a fbl yet in your case..
BarracudaHockey 08-19-2012 03:46 AM
Quote:
ORIGINAL: Solman
+1
