Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
3W-60K Lives On.
Reply
Old 12-19-2010, 06:16 PM
cap10b
cap10b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 3W-60K Lives On.
All,
3W-60K bought from a friend of mine that wanted a newer motor for towing big gliders.
Got it installed it in a WH Cap232. One of the first thing I did was blow the 4.8 VDC ignition. I replaced it with an
RCXEL unit from WildHare RC.
RPM Numbers
32:1 Penzoil Aircooled oil
93 Octane Shell Unleaded
22x12 Zinger 6500
22X12 3B Mejzlik CF 5100
23x10 WH Bunny prop 6600
24x10 WH Bunny Prop 5900
24x8 Topflite Power Point - 6500
24x8 WH Bunny Wood Prop - 6350
The motor gets alittle hot (around 180 degrees in the cowl) and 210 on the ground. Baffling should take care of that.
I forgot just how much the normal aspirated motors spit. This one produces a healthy stream down the fuse even covered
up with the cowl. Got the tuning down on this motor now, all the heat problems solved wtih baffles, makes the Cap 232 into
a good Aerobat model capable of anything the pilot can do.
LOVE THIS MOTOR.
jds
Well so much for flying my new toy, the covering came off the wing. I guess that 3W-60K is so powerfull it rips the covering plum off.
Repaired the coveringer flew the plane again and this time I really snapped and stressed the wings, all ok.
ID:	1536194   Click image for larger version
ID:	1536195   Click image for larger version
ID:	1536196   Click image for larger version
cap10b is offline
Old 12-19-2010, 06:44 PM
krayzc-RCU
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 3W-60K Lives On.
way to go is that on a muffler?
krayzc-RCU is offline
Old 12-19-2010, 06:48 PM
cap10b
cap10b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cap10b is offline
Old 03-22-2011, 02:13 AM
cap10b
cap10b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More 3 dub-ya 60 stuff finally got the CAP set where I want it. Wing covering all nailed down and the surfaces all tight.
Also have the RCEXEL Tachometer installed and reads
24X10 Bunny wood prop 6100 RPM Not bad for a 25 year old motor.
ID:	1582486   Click image for larger version
ID:	1582487   Click image for larger version
ID:	1582488   Click image for larger version
ID:	1582489   Click image for larger version
ID:	1582490   Click image for larger version
ID:	1582491   Click image for larger version
cap10b is offline
Old 03-22-2011, 08:36 AM
krayzc-RCU
My Feedback: (31)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
man that great and i love those caps
Old 03-22-2011, 03:18 PM
MetallicaJunkie
MetallicaJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nice motor....when did it come out?
MetallicaJunkie is offline
Old 03-24-2011, 04:57 PM
cap10b
cap10b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Late 80's early 90's
cap10b is offline
Old 06-08-2011, 07:24 PM
cap10b
cap10b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Testing
cap10b is offline
Old 06-14-2011, 07:28 PM
MetallicaJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: cap10b
wow and i thought 1.08s were big in the 80s
Old 06-18-2012, 03:40 PM
cap10b
cap10b's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All,
The 3 Dubya has found a new home. Check out my Wild Hare F6F Hellcat
JDS
cap10b is offline
Contact Us Archive Advertising Cookie Policy
