Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Saito 100T RPM's
Old 10-07-2011, 12:28 PM
TCraft Lover
Default Saito 100T RPM's
I'm reading about 8550 rpm on my 100T using a 14-6 MAS wood and 15/18 Wildcat fuel. Can anyone tell me if these readings arereasonable for this prop fuel combo?
Old 10-08-2011, 07:11 PM
TFF
Default RE: Saito 100T RPM's
That seems about right. Twins make less power than singles, but it seems pretty strong.
Old 12-18-2011, 05:53 PM
Iflyglow
My Feedback: (79)
Iflyglow's Avatar
If I remember correctly, my 100T turned approx 9,800 with a APC 14-6 on WC 20/20 with OS F plugs.
Old 12-19-2011, 03:23 AM
TCraft Lover
Wow that seems really fast! After I ran my motor I took if off the stand and decided to check the valve clearance and found that there wasn't any.Couldn't get a feeler gauge in at all. I guess I should have checked it BEFORE I ran it! Anyway I set the clearance to about .003. I'm hoping to get a little higher RPM.
Old 09-08-2012, 01:09 PM
TCraft Lover
Just got the 100T off of the test stand after adjustingthe valve lash to .003. With 10/18 fuel and a 14X6 MAS wood I'm getting a peak tach reading of 9000 or just a titch over. I can live with that number better than the 8500 I was getting before.
