Enya SS30 BB
RE: Enya SS30 BB
I still haven't got my airboat ready yet. It just needs the radio installed. I guess it could go on the snow. It's a Big Swamp Buggy. I got a smaller one too that I haven't tried yet. It doesn't look like as much fun. I think the swamp buggy would unload a bit when it is moving too, but I think the low pitch and big dia. props are the fad for them.
RE: Enya SS30 BB
ORIGINAL: aspeed
I'm still trying to clean the castor goo off my test stand... That little Enya without a muffler made a royal mess. 25% castor will do that though.
ON, CANADA
RE: Enya SS30 BB
ENYA 25 SS
I have a used Enya 25SS that was in a Wonder. I was wondering if it is BB or not. I took the front housing off but still cant see any bearings. Do I have to pull the crank etc. to see them?
Also, I see the nice testing done on the Enya 30SS. Can I assume that the 25SS will give somewhat simiar results?
Does anyone know if there is any test results for the Enya 25SS in a thread somewhere.
Thanx for any info.
Dan in Ottawa
Thanx for any info.
Dan in Ottawa
RE: Enya SS30 BB
ORIGINAL: mcledan
ENYA 25 SS
Thanx for any info.
Dan in Ottawa
ENYA 25 SS
Thanx for any info.
Dan in Ottawa
If your engine is a BB engine, there will be a raised "snout" on the front of the engine right behind the prop driver. BB engine:
Bushing engine:
This is on a *bay ad, and its hard to see the front of the housing, but if you look carefully you can see the engine doesnt have the raised bump for the ball bearing.
http://www.ebay.com/itm/ENYA-SS-30-R...4583%26ps%3D54
The bushing engines tend to run a few hundred rpm less than their BB counterparts, generally. Based on the SS25 AAC numbers from above on 15% nitro, It would probably be 300-400rpm less on 5% nitro which is what they should really be ran on.
ON, CANADA
RE: Enya SS30 BB
Thanx. I did not get back to you as I focussed on the other thread, sorry.
I will put the engine back together and try to get a run on it.
It had red thread locker on it, so I will add some fresh stuff and put it togrther.
Its a bit busy, snowy and cold at the moment here in Ottawa..
Its probably a lot nicer Wx wherever you are ;^)
Cheers
Dan
Cheers
Dan
#31
RE: Enya SS30 BB
ORIGINAL: mcledan
Cheers
Dan
Cheers
Dan
We have a high of +20°F with some wind. Its +10°F right now at 8am Central time. I ran my SS30 the other day and actually had a propane heater going in the garage to thaw my fingers out between prop changes. It got so cold, I had to use a putty knife to scrape the Castor sludge off my test stand and concrete floor. I still dont know why, but I giggled like a little school girl doing this. This gnarly thick oil is almost all I use anymore.
#32
ON, CANADA
RE: Enya SS30 BB
Thanx 1QwkSport2.5r. I wont use the red locktite. Blue it will be.
The 4 bolts holding the front housing to the main case had the red locktite.
They were not too hard to remove. OTOH maybe it was some other red compound, dunno.
Its up to 0'C/ 32'F just now with lots of snow from the Colorado Low coming through.
Down to -10C/ 10'F tonight, -15C/ 4'F and staying there for a few days.
I wont be running my engine in the garage.
Cheers
Dan
Cheers
Dan
#33
RE: Enya SS30 BB
Do you run the airboat with the flat bottom that kind of slides in the turns , Ive had a ST45 in one and its good , The heli mufflers have that big volume and they claim some good power , I dont doubt it , I run a mini pipe so I have not tried big volume , but it looks good
#34
RE: Enya SS30 BB
ORIGINAL: 123Cat
