Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Any readings on Saito FG36?
Reply
Old 04-24-2012, 08:56 AM
PhoenixRock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Any readings on Saito FG36?
Does anyone have any readings on the Saito FG36?
PhoenixRock is offline
Old 05-01-2012, 03:10 AM
jamesroutledge
jamesroutledge's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Any readings on Saito FG36?
The silence is deafening!
jamesroutledge is offline
Old 05-01-2012, 03:31 AM
PhoenixRock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At least you are talking, James!...
It's killing me!
Old 05-07-2012, 04:11 AM
jamesroutledge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looked around on Youtube for FG36.
Most guys who give the prop size are using 18x8 or 19x8.
7200 to 8000 rpm
Old 05-07-2012, 04:55 AM
PhoenixRock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
James,
Also read quite a lot over the weekend...
Tested it yesterday afternoon and got 7850 with the 18X8.
I have ordered the 18x10 and 19x8 and will try them as soon as I get them!
Old 05-07-2012, 12:23 PM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been looking for a 30-40cc FS for a project of mine and from what i am seeing the Roto motor 35FS is stronger than the Saito and is very close to the same weight. it also about 50 dollars cheaper. it turns a 20x10 6,000
airraptor is offline
Old 05-08-2012, 09:21 AM
jamesroutledge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know this is off topic and I apologise to other users, but I also know this FG36 is in a Typhoon. Check out this video http://www.youtube.com/watch?v=Fo0Lv...eature=related and this video http://www.youtube.com/watch?v=qexMo...eature=related .. Awesome plane.
Old 05-08-2012, 12:58 PM
jamesroutledge
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
7850 rpm on an 18 x 8 is barely 1.5 hp and 3.75 kg thrust according to ThrustEstimator. A strong 61 two stroke makes that horsepower!
MVVS-prop-power-calculator gives 2.17 hp and 7kg thrust.
Will be interesting to put a scale behind it and do an actual thrust measurement.
Must try APC props !
Old 05-08-2012, 11:23 PM
PhoenixRock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
James, where do I get a hold of those calculators / thrust estimator?
I have a "Prop-power-calculator" which gives me 8.3kg static thrust, needing 2.69 hp, on the readings mentioned.
I will however put an electronic scale on it this weekend...
Old 06-02-2012, 10:42 AM
SrTelemaster150
SrTelemaster150's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: PhoenixRock
James,
That's what I get W/a Saito FA150 W/a Dynathrust 18 X 8 when running C&H electronic ignition W/15% Morgan's Cool Power. 23% longer run time on a given fuel load @ WOT.
7700 W/the same prop/fuel on glow ignition.
I get 8000 W/that prop/fuel W//an FA 180 on glow ignition. Hoping to get about 8200 on spark ignition W/the 180.
A timed spark is a wonderful thing for power & fuel economy.
SrTelemaster150 is offline
Old 06-02-2012, 10:47 AM
SrTelemaster150
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: jamesroutledge
I have a ''Prop-power-calculator'' which gives me 8.3kg static thrust, needing 2.69 hp, on the readings mentioned.
According to this calculator http://personal.osi.hu/fuzesisz/strc_eng/index.htm that takes the prop diameter, pitch, prop design & amnient temperature, that's 2.759 HP & 17.64# of static thrust.
The HP for 7700 RPM is 2.6HP which is pretty close to Saito's FA150 factory HP rating of 2.5HP.
Old 03-10-2013, 04:04 PM
akouzmit
akouzmit's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, Here is field measurements taking with electronic scale (fish scale max 20kG):
SAITO FG-36B (Stock ignition replaced with RCEXL hole sensor based ignition).
Prop: Xoar 19x8
Max RPM 6870-6980 (Note: It is not optimum RPM for this engine in order to get max HP out.)
Static thrust 5.5kG - 5.7kG
I am going to use APC 18x6W in order to get my target of 8500RPM (8300-9000RPM considered the best for max HP output).
I hope static thrust may go up a bit due to low pitch prop working better in static conditions.
From today test I think 19x8 is a bit too much for FG-36 in order to get max HP output.
With Xoar 18x8 I have measured earlier I was getting somwhere around 8000RPM. No thrust measurement was done at that time.
Need to repeat my experment with 18x8 again and measure static thrust while waiting for APC 18x6W to arrive.
Anyone can share field measurements with other props?
Thank you,
Andrei K.
akouzmit is offline
Contact Us Archive Advertising Cookie Policy
