Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Enya 60-4C
Reply
Old 09-07-2012, 03:08 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Enya 60-4C
I got this engine NIB, and I believe it to be one of the earlier 60's as it didn't come with a muffler. It seems that the newer ones came with a muffler but it was optional on the older ones. Either way, I run mine with the open header and no muffler. Tank vented. I did an experiment with glow plugs, trying 3 different plugs. I have one left to test.
71°F / 42% humidity
5/20 fuel, APC props
OS F plug, lowest idle rpm/peak rpm
12x6 - 1800rpm/9930rpm
13x6 - 1600rpm/9720rpm
Fox Miracle plug
12x6 - 2400rpm/9630rpm
13x6 - 1900rpm/9630rpm
Fox Idle Bar plug
12x6 - 1400rpm/10,110rpm
13x6 - 1600rpm/9720
I have a McCoy MC4C plug I will try next time I get a chance. Top rpm was the same between the F plug and the idlebar, but the idle quality, speed, and transition was better with the idlebar plug. The idle was set burbly rich since thats what it likes, and the transition was smokey but acceptable. It needs more run time I think, but overall it runs pretty well.
1QwkSport2.5r is offline
Old 09-19-2012, 07:43 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Enya 60-4C
61°F air temp, 5% nitro 20% castor fuel, 11x9 APC prop, Idle speed set at about 2900rpm.
Fox idlebar plug - 9930rpm peak
OS F plug - 9900rpm peak
McCoy MC4C plug - 9830rpm peak. Transition was the best with this plug; burbly rich but faster and smoother.
Old 09-19-2012, 08:03 AM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
only 210 rpm from a 12x6 to a 13x6 indicates its a torquer. try a 14x6 on her.
airraptor is offline
Old 09-19-2012, 08:15 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: airraptor
Dont have the clearance to run a 14" prop, have to shim the engine up to make a 13" clear. Looking for more speed than a 6" pitch prop can provide. I want to get a 11x11 or 11x12 to test on this engine. This engine seems to like running in the 9000-9500rpm range, but has no problems revving up higher. It is said (according to an article I read) that this engine makes its peak HP at 11,800rpm.
I'm not fond of the OS plug, it does not have as good idle quality compared to the idlebar or mc4c plug.
Old 11-10-2012, 05:41 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran this engine a little more today since I had an hour to kill. APC 12x6 = 10,100rpm peak. MAS K-series 12x6 = 9,800rpm. 5% nitro 20% castor, Enya #3 plug, 60°F air temp and humid.
This engine is coming into itself now. Either that or I'm getting the "knack" for getting it adjusted right. It has to have a rich low end, so transition right off idle is a little burbly and it stumbles a little, but otherwise it revs up nicely. I've been setting it 300rpm rich from peak on a full 8oz tank, and I get at least 15 - 20 minutes run time with maybe 1/8th tank left.
Old 11-13-2012, 05:26 AM
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good numbers Quick, that is a fine engine as are all Enyas, I think I could safely predict that with a muffler and a pressure tap you could eliminate that need for the rich low end.. That was the case with my old .46MKII
Hobbsy is offline
Old 11-13-2012, 06:35 AM
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought this engine in 1989 and it was my first RC engine. I was dumber'n a mine mule concerning RC engines but read on the old RCOnline that the Enya fourstrokes could benefit from a pressure tap. Having an understanding about pressure waves and pipe tuning on dirt bikes I put the pressure tap dead center in the muffler. A couple of years later I got an Enya .53TN and it had the pressure tap on the muffler cap on the engine end of the muffler. Go figure.
Hobbsy is offline
Old 11-13-2012, 03:15 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I actually tried a muffler from a Saito that my buddy gave me and it still needed a fat low end to transition right. It would cut out if you opened the throttle even moderately quick. The instructions from Enya say something like "Usually, 60-4C prefers rather rich mixture at idling". They aren't kidding. If I get the urge, I'll track down a muffler. The 60 loses about 400rpm with a muffler though.
I do find it amusing when I rev the 60 up, I can see the oil spewing out of the exhaust. The other day when I ran this engine, the weather was somewhat chilly and the oil coming from the breather got rather thick and wouldn't come out of the tubing, so I had to blow the oil out of the line and then it was breathing okay after that. I guess thats what I get for running the full-castor package and not putting a Bowman ring in it.
It is a reliable engine, no doubt, so long as the idle is rich enough. It will tell you its not rich enough if after running up to WOT and back to idle it quits. I had this happen once while setting it up the other day and all it took was 1/16th turn of the airbleed richer and it was fine then.
I will have more Enya engines for sure. This one and my SS30 are two of my favorites. The SS30 is the #1 fave right now, its a real sweetheart. The most reliable engine I own, bar-none.
Old 11-13-2012, 05:39 PM
Hobbsy
My Feedback: (100)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure you get all the old oil, (and water) out of the cam box when running on a cold day, Enya fourstrokes rust like crazy in the cam box. I remove the carb mount screw from the cam box and inject NAPA Fogging Oil when its going to sit a while.
Hobbsy is offline
Old 11-13-2012, 06:11 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Hobbsy
I try not to let it sit too long without running it; I try to run it at least every other week. I'll pull the cover off and inspect it, and oil it up good.
Edit: I would have to remove the cam box to lube it; the carb retaining screw doesn't go into the cam box like the .46's do and the others like it. I pulled the cam box cover plate and got a handful of clean castor oil all over my hands. I squirted some of my homebrew ARO into the breather, inside the rocker cover and into the cylinder and spun it over good. I ran the engine dry when I was done with it last.
Old 05-14-2014, 06:36 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ran the .60 the other day. 12x6 APC prop, Enya #3 plug, 10% nitro / 20% castor fuel. => 10,300rpm. Nice improvement with a little more nitro. Maybe it's finally breaking in some. Trying an 11x7 next.
Old 05-15-2014, 02:45 PM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
is this going in a boat?
the 11x11 is a big jump from a 12x6
Old 05-15-2014, 03:11 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might want to re-read my last post.
Old 05-15-2014, 05:19 PM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
quick your to quick again. i guess i need to spell it out more clearly for you. in post number four you were talking about trying a 11x11 or a 11x12 this is what I was refering to.
"Dont have the clearance to run a 14" prop, have to shim the engine up to make a 13" clear. Looking for more speed than a 6" pitch prop can provide. I want to get a 11x11 or 11x12 to test on this engine. This engine seems to like running in the 9000-9500rpm range, but has no problems revving up higher. It is said (according to an article I read) that this engine makes its peak HP at 11,800rpm.
I'm not fond of the OS plug, it does not have as good idle quality compared to the idlebar or mc4c plug. "
Old 05-15-2014, 06:48 PM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I guess I was assuming since you didn't quote anything and this thread hadn't been posted in since November 2012 that you read the last post wrong. Why reply and refer to a very early post without quoting anything? It's unimportant anyhow.
A lot of times, I run an engine just to run it and see what it does. This engine has been sitting on the shelf for awhile since I replaced it with a R120-4C. I haven't been able to get my hands on any 11" props with more than 9" of pitch. Which is fine because that's too much prop anyway. An 11x9 turns around 9k, an 11x11 would be in the low 8k's and I'm finding these Enya 4-strokes need to rev up. They will tug away at 9k all day long, but the carb reversion is so bad in bigger props that it's just too damn messy. Smaller props make less mess.
So to answer your previous post, yes it's a big jump. Too much prop for nearly all of the engines I have except maybe the R120. Not going in a boat. Took it off of one. Might put a clutch and flywheel on it and put it in one of my 1/8th scale 4x4 monster trucks. Needs a custom gear unit to up the rpm going to the transmission though. Might make a good crawler without the gear unit....
Just thoughts for now. Engine is going on the shelf with the others for now.
Old 05-15-2014, 08:20 PM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ha i didnt even see that. i know you're always trying stuff. send me your address and I will send you some props to try.
Old 05-17-2014, 02:24 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mind if I ask what you have in mind? I'll try almost anything, just curious what you have.
Old 05-17-2014, 08:33 AM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have 11x10, 11x11, 11x12,11x13 and 11x14
Old 05-17-2014, 09:59 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I suppose they won't really unload ( or hook up for that matter) on the ground worth snot, eh? I suppose it'd have to be really moving to unload at all.
Thanks for the offer, I'll think it over. I don't know if they'd work for what I'd use the engines for.
Old 05-17-2014, 01:21 PM
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No they dont really need be over 120 or so with the 11 and more with the others
Old 05-18-2014, 04:11 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I do appreciate your offer, but I don't think I can make any use of those high pitched props at least for the foreseeable future. Test stand running maybe, but not in a plane. Thanks anyway.
Old 09-23-2014, 03:56 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
72F air temp, 10/20 fuel, Enya 3 plug, new crank bearings.
13x4W APC - 10,200rpm peak, 1,500rpm idle
11x5 MA - 12,330rpm peak, 2,300rpm idle
11x7 MA - 11,700rpm peak, 2,300rpm idle
12x6 APC - 10,440rpm peak, 1,850rpm idle
The 11x5 is probably too small for flight due to prop unloading, but the carburetor reversion was zero on all props but the 12x6. Using a little more nitro may have helped with this as well. No knocking or pinging, lowest idle speed noted was 1,250rpm but it wasn't stable. Fantastic sound at that rpm though.
Contact Us Archive Advertising Cookie Policy
