Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Novarossi R26CR
Reply
Old 07-07-2015, 06:20 AM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The side exhaust is actually a little more flow friendly than the rear exhaust configuration generally, but Dub says the rear exhaust and side exhaust engines run the same. The LX engines are timed higher than the standard engines and come with the gold muffler standard. A tuned pipe can be added and Dub tunes the pipe to your specs. He sent my 56LX with the header 1/2" longer than "peak" length so when the engine is broke in and running good and not blowing plugs, he instructed to cut 1/2" off the header and go play. I have a standard .35 as well and it will not turn the advertised ground rpm published on Dub's site even after a couple gallons of fuel. I suspect the elevation/climate I am in has a lot to do with it. It's down about 700-1000rpm at peak from where it should be. I concur with airraptor on the bearings. Keep an eye on them in the .35.
1QwkSport2.5r is online now
Old 07-07-2015, 06:39 AM
jasonvo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the info on Jett BSE .35, I asked Dub do the break-in for me and check the engine after break-in.
jasonvo is offline
Old 07-07-2015, 07:35 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All Jett engines are test-run at the factory. Why ask him to do the full bench break-in? You're not learning how the engine runs or how to handle it (needle settings, fuel tank setup) by having him do so.
Old 07-08-2015, 09:44 PM
jasonvo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't want to spend time on break-in the engine, it bother my neighbor I had experienced with nitro engine so tuning is not a problem. Thanks for the input, I will keep my eyes on Jett engine.
jasonvo is offline
Old 07-09-2015, 12:53 AM
1QwkSport2.5r
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good luck with that.
Old 07-09-2015, 09:25 AM
  #31
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
break the engine in while flying it. Run it rich on a smaller prop.
airraptor is offline
Old 07-09-2015, 06:06 PM
  #32
jasonvo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good Idea, we can break-in the engine and have fun the same time
jasonvo is offline
Old 07-09-2015, 06:47 PM
  #33
jasonvo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by speedracerntrixie View Post
Thats funny. I ran my Rossi at 16,500 or there about and won a couple season championships with it. I suppose you have more experience then I. Carry on.
what prop size and engine you are running sir?
jasonvo is offline
Old 07-09-2015, 09:42 PM
  #34
airraptor
My Feedback: (66)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
speed was running a Rossi 61 with a pipe. I think it turned a 11x11 prop at 14,000 or so.
Old 07-12-2015, 06:17 PM
  #35
jasonvo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no wonder
jasonvo is offline
Old 07-12-2015, 06:29 PM
  #36
jasonvo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Updated Rpm from my Novarossi R26CR fully broken-in with Macs Tuned pipe.
Nitro 15% :
MA s2 scimitar 8x6 17,500 rpm with Macs tuned pipe and engine mods 19,800 rpm
APC 8x6 15,900 rpm with Macs tuned pipe and engine mods 17,800 rpm
Prop size per Novarossi website for this engine 8x4 - 8x6, 9x5
jasonvo is offline
Old 07-12-2015, 06:39 PM
  #37
jasonvo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by särpet View Post
new Novarossi Cesare Rossi plane line R26CR
weather -1 to+1 c
fuel 10synthetic oil 10castor oil 10nitro
master scimitar 9x4 17900-18000rpm
apc 9x4 15900rpm
master black prop 9x5 14800rpm
apc 9x5 14400rpm
fuel 15%nitro castor/synt oil 18% and hatori muffler
apc 9x5 14900rpm
ma sci 9x4 18600rpm
0%nitro ma sci 9x4 18100rpm
Sir, was this data after engine fully broken-in? do you have any update?
jasonvo is offline
Old 08-13-2015, 09:14 AM
  #38
sarpet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ithink it was broke in.
9" props are too big with standart muffler.
Apc 8x4 ,15%nitro is great 19200rpm ground
sarpet is offline
Old 04-28-2017, 06:25 PM
  #39
Pond Skipper
Pond Skipper's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Published on Nov 28, 2015
OS FX .25 with MACS Tuned Pipe APC 8x8
16,149 rpm / 122 mph / 3.1 lbs thrust / .994hp or 742w
Quick rev up during break in mode, header cut to 4.25"
Tru Turn 1/4-28 spinner nut.
Should do 17k after break in was about 3/4th turn rich.
Pond Skipper is offline
