Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Webra .35 Speed
Reply
Old 04-02-2004, 02:55 PM
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Webra .35 Speed
Webra .35: 4000', 65 deg., 15% Powermaster, O.S.#8 plug, Mac's Muffler (6650), 10x6 APC, after 32oz of fuel
11,800 peak rpm
TimC is offline
Old 04-02-2004, 08:41 PM
Rudeboy
Rudeboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Webra .35 Speed
That's too low... It should do more on a 10x6...
I think you are killing your engine with too much nitro and a plug as hot as that OS #8...
Shim the head, or switch to 5% nitro.
Rudeboy is offline
Old 04-03-2004, 02:32 PM
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried it with 5% Cool Power with 2 oz. of castor added to the gallon: 11,210 peak. The 15% runs fine with no sign of detonation or over-heating. I'm assuming Webra shims the head for the U.S. market.
TimC is offline
Old 08-05-2006, 08:11 PM
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Today was about 100°F. I decided to try an 11x4 APC. Using 15% PowerMaster, it peaked out at 11,700 rpm.
TimC is offline
Old 08-06-2006, 09:26 AM
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you have an APC 9x6 to try? I thought the Webra's in general liked to rev a little higher. What plane do you have it in?
Have fun, MikeB
WMB is offline
Old 08-06-2006, 01:38 PM
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here you go Mike, 9x6 APC: 15,450 rpm peaked. This is the highest rpm I've ever run an engine. It sure screams. My computer for some reason won't download the thrust/horsepower calculator avaible on line, even after I installed the required program to run it. I'd be heap grateful if someone would crunch these numbers:[ul]
[*9x6 APC 15,450]
[*10x6 APC 11,800]
[*11x4APC 11,700]
[/ul]
I'm still looking for a good plane to put it in.
TimC is offline
Old 08-07-2006, 08:05 PM
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Tim. I've got the OS32F that will be going into a Sig Kobra. Your running a little stronger than mine. I am about ready to start covering. Hope to get it in the air soon. I've heard of a 25 size 300 arf Extra. Have heard good things about it, don't remember the mfg.
Take care, MikeB
WMB is offline
Old 08-07-2006, 08:13 PM
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike, I think I have that little Extra (ModelTech) with an O.S. .32SX in it. It's a sweet little plane and quite a bargain at $80. I like the O.S. fine and wouldn't think of swapping it out for the Webra.
TimC is offline
Old 08-16-2006, 08:55 AM
HaveBlue
HaveBlue's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran the figures through, but at normal air density..not sure how much your elevation would effect these figures
9 x 6 @15450 = 87.79 mph/ 1.037 HP/4.07 static lbs thrust
10 x 6 @ 11800 = 67.05 mph/0.704 HP/4.18lbs
11 x 4 @ 11700 = 44.32 mph/0.670 HP/6.01 lbs
HaveBlue is offline
Old 08-16-2006, 10:41 AM
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks a heap HaveBlue. MikeB was right; this engine is a revver.
TimC is offline
Old 02-21-2010, 01:44 AM
Ernie Misner
Ernie Misner's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Tim, are you still following this thread? Long time no hear from you! I still have an OS 32 and a webra 35 myself. Both need a plane.
Ernie
Ernie Misner is offline
Old 02-21-2010, 09:18 AM
TimC
TimC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How's it going Ernie. I still visit RCU now and then, but I haven't been doing much flying. The .35 is not in a plane. One of these days I'll get fired up on flying again and find a plane for it. I hope things are going well up your way.
TimC is offline
Old 02-25-2010, 10:29 PM
RocketRob
RocketRob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the numbers guys. Don't have a 32 but my webra .28 diesel spins a 10x6 (Bolly and APC) 11,900 to 12,100 - havn't run one of the glows yet but will use a 9x6
RocketRob is offline
Old 02-28-2010, 11:37 PM
freakingfast
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These are my notes from years ago, on hind sight I think I was running too much nitro and/or wrong plug (OS#8), because I remember plug life was a bit on the short side. Webra 35 ringed with Macs muffled tuned pipe, running Powermaster 15% nitro.
16,500 with 9X6 APC
17,700 with 8X8 APC
Note, these are nearly identical results to a same setup OS 32 SX. Fuselage(glass F-3D) vibration was higher with the Webra and extra measures were needed to keep the fuel from churning at high RPMs. The break-in process was longer with the Webra.
freakingfast is offline
Reply
Display Modes
