ST 2300
MS
RE: ST 2300
The Magnum carb is around $35 is I remember correctly from the Distributor's web site. I would buy anothe engine before I spent much on the 2300. If you want performance go with Saito, Magnum, or OS.
MS
RE: ST 2300
If you go to Tower Hobbies web site they give the dimensions of the carbs. Many carbs like the Magnum will need an adapter to work. A machine shop can turn you one out of aluminum.
NH
RE: ST 2300
Just got a perry carb model 5002 (only $29 at my lhs) for mine. As I am not allowed to run the motor in my house and it is terrible weather outside I will have to wait to see if this combo works. I have a perry vp30 pump/regulator and a bisson pitts muffler. I hope this cures the midrange blues.....
#31
RE: ST 2300
Beach,
Thanks for the comeback, and please let me know what you find. KWeasle has been VERY helpful on this topic. If you would like explicit fix options for this engine, email or PM me, and I will send you the link I received. I will take pictures of my the Super Sportster I got with the Super Tigre 2300 on it. Massive plane, with a massive engine. I can't wait to get this thing in the air. I spent 7hrs at the field today, got a lot of sun, some pit area clearing work done, and oh ya, quite a few flights. Getting pretty comfortable with my Ultra Sports. For such an old plane (80's) arf, it just plane flys to no end, a lot of fun, such a calm day I finally got it trimmed out dead center on all surfaces, making for even more exciting low passes 10". I am going to look into a kit for a new one and built it as it just flys so nice. Awesome day.... Greg
#32
My Feedback: (21)
PA
RE: ST 2300
Hey Guys,
Hate to resurrect an old thread but I want to ask a question again that someone else asked in this thread but never received an answer to. Has ANYONE used the Jett red carb on this engine??? What were your results?? Good, bad or indifferent, any info would be greatly appreciated.
thanks
thanks
#34
NH
RE: ST 2300
Well I just noticed that I never responded to this. I have removed the Perry Carb as it made hand starting impossible. I also lost some top end RPM's with it and could not get this thing adjusted. The low needle setting is too touchy. I could not find the right combo with this carb so I put the stock one back on. I need some nicer weather and some time with the stock carb but think I can get it to where I am happy.
ORIGINAL: beachflier
#35
AZ
RE: ST 2300
G2300 MKII - purchased new early 2007 - MAS Classic 18X8 - 3000 ft elev. temp about 85 degrees F. Super
Tigre specified breakin except ran it from idle to wide open and mid range to wide open ala Gierke style. Two
18 ounce tanks until dry. 8200 rpm - 300 rpm rich. On a New Goldberg Wild Stik. Byron 15/18 some castor.
OS#8 glo plug. Stock carb and muff.
