If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 45
  1. #1
    sea fury's Avatar
    Join Date
    Mar 2003
    Savannah, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Saito 180 performance
    APC 16x8, 9500 rpm, 20% heli fuel, saito plug. I will be posting readings with 18x6 next week.
  2. #2
    Join Date
    Jan 2003
    staffordshire, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Saito 180 performance
    Graupner 16x8, 9400, 5% nitro Saito plug.
    Cheers.
  3. #3
    sea fury's Avatar
    Join Date
    Mar 2003
    Savannah, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    APC 18x6W, 8900 RPM, Saito plug, 20% heli fuel.
  4. #4
    Join Date
    Sep 2002
    Idaho Falls, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    APC 18X6 W os type f plug 30% nitro perry pump slimline pitts , 9100rpm
  5. #5
    tigil's Avatar
    Join Date
    Nov 2003
    Estrie, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sea fury
    its not much for a 180 engine
  6. #6
    Join Date
    Jan 2003
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Tigil.
    Not that bad 9500 on a 16x8 comes out at around 3.2hp.
  7. #7
    tigil's Avatar
    Join Date
    Nov 2003
    Estrie, QC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: futaba1024
    Tigil.
    it just look less then I thinking because I turn already this prop with my oldest YS 120 nearly this rpm
    9200 with cheap power master 15%
  8. #8
    PlaneKrazee's Avatar
    Join Date
    May 2002
    Gales Ferry, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    30% nitro makes a thirsty beeotch. Chug-a-lug.
    a never-ending battle for truth, justice and the American way
  9. #9
    Join Date
    Sep 2004
    STOCKHOLM Akersberga, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    MenzS 18x6 and 10% nitro fuel 8600rpm. Pulls really nice I will try the APC 18x6W soon and some thrust measuring and report back the rpm and thrust.
  10. #10
    Join Date
    Sep 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi,
    I did some flying and tach readings today. It was cold -5degrees celsius. Fuel was 20%oil castor/synthetic and 10% nitro.
    The same MenzS 18x6 turned 8400rpm today and pulled 18,5LBS on my fishing scale. APC 18x6W turned 8100rpm and pulled 17,5LBS.
    I think the lower number for today is because of the colder weather and my high oil fuel gets pretty thick and slowing things down.
    When airborne I could not really tell which was the best prop but give a slight edge to the MensS pulling slightly better. Both these props are very good for hovering "training"[8D]
  11. #11
    Join Date
    Sep 2003
    Tucson, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    20/20 fuel, 18X6 Mezjlik, 2800 ft. of elevation and I'm getting 8500 usable rpm
  12. #12
    Join Date
    Jan 2006
    New Milford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Just got my 1.80 tuned today. It's got about 1/2 gallon through it. Wildcat 15% and MA classic 18x6 turned 8600RPM. Idled smooth at 1650 with glow heat, upped it to 2000 without heat. pulled 18 1/4 lbs on my thrust meter.
    almost forgot. 40 degrees F.
    Club Saito member #173
  13. #13
    Join Date
    Jan 2006
    New Milford, CT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Don't know if anyone reads this thread anymore, but thought I'd post this anyways. I need to run a Cline regulator on my 1.80, so I wanted to get it set up on the test stand befor going into the plane.
    about 47 degrees F
    wildcat 15%, 18%synth/castor blend
    MA Classic 18x6
    Cline regulator
    8800 rpm
    idled as low as 1350-1400 rpm, no heat (sounded like it wanted to stall, but ran for a full minute befor I turned it up to a smooth
    1800 rpm idle. Idled at 1800 for 2 minutes, smack the throttle wide open, not a problem...8800 rpm.
    It really likes the steady fuel pressure with the regulator.
  14. #14
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rex,
    I have been useing them since 1995. Every engine that I have ever ran with a Cline responds that good. I have ran everything from a Saito .30 to a Saito Super Tiger 3000 on a Cline. The best set up ever with the Cline was with a Saito 1.0 Twin. That engine would idle @ 1700 for a half hour on 20/20 and never drop a cylinder. Too hear the crisp throttle responce of the little twin was something to behold.
  15. #15
    Join Date
    Sep 2002
    Bruce, MS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just traded for two 180s and tested them with 17X6 APC prop. Both engines came in at 9000 to run with this prop. Anyone that hasn't tried the 180 needs to give it a try. Idles great and transition is great. I must add that the Super Tiger 2300 will pull right with this engine but the transition isn't as quick.
    Buzz
  16. #16
    ShortField's Avatar
    Join Date
    Aug 2007
    Williams Bay, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hum?? I don't think my Tach is broken but I did a static run up with an APC 17x8 prop on my Saito 180 and was turning 12690 rpm
    RunWay? What RunWay??
  17. #17
    ShortField's Avatar
    Join Date
    Aug 2007
    Williams Bay, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My tach is broken [&o]
  18. #18
    ShortField's Avatar
    Join Date
    Aug 2007
    Williams Bay, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Got my tach working correctly
    17X8 APC prop 7800 rpm's static run up and running on the rich side
    idle at 1650 rpm's with no glow heat
    and idle down at 1470 rpm's with no glow heat
    edit spelling
  19. #19
    Join Date
    Jun 2005
    Abingdon, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sweet ok Ill post this up here. Toped out at 8670rpm with a Xoar 18x6 but still a bit rich. Not bad for this engine. Just put the Iron Bay Regulator back on and a Turbo Header first run in months so wanted to get the oil back in her.
    Some of ya are pulling really good numbers. I hope mine gets up there someday
    More info on Saito\'s http://saito-engines.info/
    Club Saito #542
  20. #20
    Join Date
    Jun 2005
    Abingdon, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Oh yeah for those interested in throttle response on the 1.80 http://www.vimeo.com/1038668 I guess proof positive ehhh
    Club Saito #542
  21. #21
    Join Date
    Sep 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    APC 18x6w @8400rpm and 17x6@9400rpm and fuel is 10% nitro. Inverted in a 60-sized Diabolic funfly 3D. Hovers at less than 1/3 throttle and then pulls vertical like there is no tomorrow
  22. #22
    Entropy's Avatar
    Join Date
    Jan 2004
    West Valley City, UT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hmmm, APC 18x6W on 15% Coolpower heli fuel. 7800 max, backed it down to 7400. Elevation of 4327 feet. 85F or 90F Degrees. Why so low? Is it just because engine has only 5 or 6 tanks through it?
  23. #23
    Join Date
    Jun 2005
    Abingdon, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thats pretty low. Dont know what could be wrong, thats hard to say. First question is are you tuning it in or just running it up with a random needle setting?
    Club Saito #542
  24. #24
    Jezmo's Avatar
    Join Date
    Jun 2006
    Spring, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Entropy
    Got another here that doesn't turn up well. In fact I am getting the same EXACT numbers as you. I am going to put another gallon through her and if it doesn't pick up to a reasonable number I am going to check the cam timing. Saito has been known to miss on occasion and get it out by a tooth and when corrected they pick up as much as 1000 rpm's or maybe a little more. Mine runs flawless, just doesn't make the grunt it should on the top end. I've tried different fuel, different plugs, checked to be sure I was getting full opening on the throttle barrel, etc. She's just not making the power to spin an 18X6 over 7600.
    Spektrum DX8i, DA DLE SuperTigre OS FOX Saito Enya Jett TT: John 3:16
  25. #25
    Join Date
    Nov 2005
    Floroe, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    My ASP 180 fs turns MenzS 18-6 at 9000 rpm on 15%, I think the Saito should do about the same
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
