ST 2000 w/MS 16x10 & Mac's Pipe
My Feedback: (-1)
CA
Initial runs (not broken in all the way yet)
High 8900 with a little surging (about 100 either way)
Low 1650
With Thrust HP program that gives 15 lbs of thrust.
Going to try different props tomorrow I think.
Low 1650
My Feedback: (15)
keep posting!!!!!!
i just got a ST 2000.. used, on a plane, hasnt run in years... im wondering what the tach diff is between a ST 2000 and a 2300 on the same prop??
Maj steve!!!! did you try an 18X8 ? i just bought one i hope sheel swing it........ i can take it back i suppose.....
My Feedback: (-1)
CA
As a matter of fact, I did try the 18-8 prop and based on the recommendation by an ST-experienced friend of mine went with the 16-10. Perfomance was improved by maybe 20% measured by static RPM and perceived performance in the air.
Used the 16-10 on the 2000-K I have with the same results. This guy's recommendation is based on his experience that these engine like high-pitch props more than RPM.
I also ran them smoking-rich at low and high end with an onboard 4 x c-cell glow lighter running ALL the time. Used a simple on/off switch on the side of the plane. I'd STRONGLY recommend this if you want good reliability with a rich setting.
My Feedback: (15)
heres a few pix
showing my ST 2000 ill post acccurate tach data ASAP was around 7200 with 16x10 but thenagain that was the first time in 10 years she had been run each tank got stronger noticably but ididn tach her...... will this weekend
http://rcuniverse.com/showthread.php...59#post1250159
Keep in mind the 2300 is a totally different animal than the 2000 and 2500. The 2300 will turn more prop at more rpm. My 2000 turns an APC 16X8 at 8000. My 2500 turns a Mezjlik 18X8 at 8900. The 2300 boasts almost 1 full hp over the 2500 (3.7 vs 2.8). ST also said to use 15% nitro and 18% oil for these engines, not 5 to 10% nitro and 10 to 12% oil (all castor) like the others. You can use 15% nitro in the 2000 and 2500, I do and seems to do just fine. My fuel also contains 18% total oil (castor and synthetic blend).
NY
You don't need to change the carb. I bought one used with a perry carb and an ST guru friend of mine made me change the carb back to the ST carb. He played with the needle for a minute then and the told me to run it and see what i think. That carb is awesome! The throttle response is simply amazing with a Zinger 18x5 even with prolonged idle at 1350. I guess the trick is you need to set the low speed needle right, with a piece of fuel tubing blowing into it.
