Quadra 35 or 42?
FL
Quadra 35 or 42?
Guesses as to what? Are you trying to determine if you have a Q35 or Q42? The most accurate way is to measure the bore diameter thru the exhaust port. A 35 has a 1 7/16" bore and the 42 has a 1 9/16" bore. It can also be done by serial #. If you need more info let me know. Regards G
