Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
MVVS / Evolution 58 tach Readings please.
Reply
Old 01-19-2006, 10:10 AM
DiscoWings
My Feedback: (76)
DiscoWings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default MVVS / Evolution 58 tach Readings please.
Post your mvvs/evo 58 tach readings
thanks
DiscoWings is offline
Old 01-26-2006, 06:26 AM
ljones5000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MVVS / Evolution 58 tach Readings please.
Is this the engine that has an "attachment" to count rpms electronically? I don' t own the engine but it seems that the technology should be there since the ignition system is "counting" how many times the sensor passes the magnet anyway. Maybe I am not expressing this correctly but hopefully, you know what I mean. Seems natural all electronically fired engines should have that capability sooner, rather than later.
Larry
ljones5000 is offline
Old 08-18-2007, 09:09 AM
AQA
AQA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Link...
http://www.justengines.unseen.org/mv360p.htm
Have fun
AQA is offline
Old 08-22-2007, 05:17 AM
duber3
duber3's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've started mine yesteday for the first time (evo58gx2)
with a wood prop 24x8 and this muffler
idle is 1600 and full rpm is 6800
duber3 is offline
Old 10-12-2007, 10:21 AM
BaldEagel
BaldEagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MVVS58Pro with a MTW 75K cannister exhaust, 22x10 three blade Mejzlik, 7650rpm. two tanks of fuel through.
Mike
BaldEagel is offline
Old 12-07-2007, 10:26 AM
zx32tt
My Feedback: (9)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MVVS 58 w/early Vlach ignition. BCM wraparound w/ rolled tips removed. 6200 on a XOAR 24-8
Z
zx32tt is offline
Old 12-11-2007, 03:57 PM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
58cc engine at sea level, ~60% humidity:
Test with MTW test reso pipe: rpm, header length cm, header dia mm; remarks
Mej 22x10, TDreso;7700;25;28; slight hunting (unstable top rpm 7600 - 7800)
Mej 24x10;TDreso;6500;25;28; slight hunting
Mej24x10;TDreso;6800;40;28; slight hunting
No hunting at richer carb settings
Tests with KS 50 reso pipe:
mej 22x10, KS50reso; 7600; 25;28; steady rpm
Tests with final (available) 4-chamber MTW tuned pipe as soon as I can manage.
pe reivers is offline
Old 12-21-2007, 06:46 PM
closetguy
My Feedback: (13)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
evolution 58gx2
header dia. 28mm
length 12"or 30cm
ES Composite pipe
Beila 24-8 carbon prop
rpms 7500
900 ft. ASL
closetguy is offline
Old 04-01-2014, 10:52 AM
särpet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Same muffler 3% kendall GT1 menz 23x8 idle 1400rpm max 6940rpm
Xoar 24x10 6000rpm
särpet is offline
Old 04-07-2014, 07:02 AM
earlwb
earlwb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was getting around 5750 RPMs using big wide Top Flite 24x10 prop. I had converted the engine to use the CH-Ignitions system versus the old Valach ignition system. CH-Ignitions has a really nice CNC machined amuminum sensor carrier. Plus the sensor only works with the one magnet, ignoring the second magnet, if you have the oder two magnet Valach system.
earlwb is offline
Contact Us Archive Advertising Cookie Policy
