Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
O.S. 70 FS (I)
Reply
Old 11-25-2002, 07:16 AM
Pepe J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default O.S. 70 FS (I)
APC 13 X 6 + 15% Nitro. + OS "F" Plug, 100' alt. = 10,500 RPM
Pepe J is offline
Old 02-14-2003, 11:35 PM
stgrlee-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My O.S. 70 is pretty new, only 3 tanks run thru it. Turns 10,200 on a 13-6 Master Airscrew.
stgrlee-RCU is offline
Old 02-28-2003, 01:24 PM
Mr T.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Re: O.S. 70 FS (I)
Same here, 10800 peaked 10400-10500 ready to fly
Quote:
Mr T. is offline
Old 03-04-2003, 03:33 AM
Keefer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
10.8K on an APC 13x6, 15% Power Master Fuel
11.25K on APC 12.25x3.75, 15% Power Master
both with OS-F plugs
Keefer is offline
Old 03-14-2003, 07:15 AM
Pepe J
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just recently switched to a fully synthetic fuel. 15% Nitro-18% oil which I added 3oz of castor for a 20% oil content. I gained an additional 300 RPM, but the TORQUE...... Big time torque improvement. I can't wait to try this fuel in my other 4 strokes!
Happy Fly'n....
Pepe J is offline
Old 04-25-2003, 11:20 AM
Toucan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 70 II Four Stroke
I am getting a 9500 to 10000 RPM with a 12X6 prop, 80-20 Fuel is that alright.
Sharad
Toucan is offline
Old 04-25-2003, 12:38 PM
Steve Guinn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is right where you want to be. Bax says they like to run them in the mid 9's for a smooth transition.
Steve Guinn is offline
Old 10-12-2005, 06:55 AM
Stoneweapon
Stoneweapon's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: O.S. 70 FS (I)
My very well used FS70 Surpass (10 Gall.+) turns with Coolpower 10%:
13x4W APC 11000
13x6 APC 10500 (private "blended" mix: 5% nitro, 11% castor, 5% molsyn 150)
Stoneweapon is offline
Old 02-12-2009, 02:48 PM
MetallicaJunkie
MetallicaJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
15% coolpower with added castor 12x7 apc and OS F glowplug 10,800 peak and 10400 to fly, i cat wait to try it out...... i got this engine "frozen" and dissassembled it a few months ago. it, set the valve lash, and finally got around to putting her in a plane.
MetallicaJunkie is offline
Old 02-13-2009, 04:13 PM
chashint
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 70 II Four Stroke
Quote:
ORIGINAL: Toucan
Sharad
I think you should get those numbers with a 13x6 prop.
A 12x6 prop is a little small for this engine.
chashint is offline
Old 02-14-2009, 01:22 AM
MetallicaJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you are right, but he isnt using any nitro in his fuel....according t0 him, its 80%methanol and 20 %lube
Old 02-28-2009, 05:37 PM
chashint
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
good catch Metallica
chashint is offline
Old 03-09-2009, 08:48 PM
buzzard bait
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm getting 9300 with 15% Coolpower on a 14x4W APC. That seems low to me. Someone else reported getting 10,000 on that prop. The engine has had a fair amount of use, but has been well cared for. Bearings are smooth, compression seems fine.
I adjusted the valves and noticed that when I press them down, they come up a little bit slowly. Not very slowly, but they don't pop right back up. Is that a sign that they've gotten gummed up (it has had fuel with castor in the past)? Could I get some power back by disassembling and cleaning?
Jim
buzzard bait is online now
Old 03-09-2009, 10:52 PM
MetallicaJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i would have to say yes
Old 04-03-2009, 03:18 PM
chashint
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't think I would disassemble it.
I would take the back plate, cam cover, and valve cover off.
Remove the glow plug.
Rotate the crank so the piston is down.
Throw it in a crock pot and cover with antifreeze until 1 or 2 inches submerged.
Put the lid on the crock pot and set the heat to low and let it cook overnight.
It should come out looking almost brand new.
Dry it (blow it out with air hose if available) and apply liberal dose of WD40 through out the engine.
Dry it (blow it) again, apply liberal dose of light weight oil (air tool oil, after run oil, marvel mystery oil).
Put the covers back on and see how it runs.
chashint is offline
Old 04-06-2010, 04:33 PM
MetallicaJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OS70 Supass new bearings 15% nitro apc 14x4w prop 10,050 tuned to fly
Edit* Surpass I
Old 04-14-2010, 12:27 PM
ton2di
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OS 70 II Surpass
APC 13x7 with 15% omega fuel 9,800 rpm
Sea level
ton2di is offline
Reply
Display Modes
