If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 4 123 ... LastLast
Results 1 to 25 of 93
  1. #1
    Join Date
    Sep 2005
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    O.S 1.20AX Owners. Post your tach readings
    My 120AX run at
    8400RPM , APC 16X8
    7700RPM , APC 10X10
    10% nitro , sea level
  2. #2
    seanychen's Avatar
    Join Date
    Jul 2002
    Canton, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: O.S 1.20AX Owners. Post your tach readings
    ORIGINAL: vlado
    My 120AX run at
    8400RPM , APC 16X8
    7700RPM , APC 10X10
    Try Master Airscrew Classic 16x8. I got 9400 with that prop.
    E_Total = M*G*H + 1/2 M*V^2
    When H=0, all of airplane\'s velocity becomes crash energy!
  3. #3
    Join Date
    Sep 2005
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i got 9400rpm with APC 15X8 10% nitro , but i think is better to know the thrust.
  4. #4
    chrisri01's Avatar
    Join Date
    Apr 2005
    Westerly, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I just started breaking my 120AX in last weekend... only 1 tank so far:
    APC 17X6, Byron 10% nitro / 20% oil, Sea Level
    8800 RPM
    9100 RPM peak (cold)
  5. #5
    Zippi's Avatar
    Join Date
    Jun 2004
    Evansville, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm using the same prop and fuel on mine and have about one gallon through it so far. Hopefully I'll maiden my Laser in a couple weeks to see how this engine runs and pulls the plane.
    ORIGINAL: chrisri01
    8800 RPM
    Attached Thumbnails Attached Thumbnails Click image for larger version.
    "It Ain't Lookin Good"
    http://www.evansvillercclub.net
  6. #6
    seanychen's Avatar
    Join Date
    Jul 2002
    Canton, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    chrisri01
    How did you photo the thermal map of your 120 AX, as in your avitar?
  7. #7
    chrisri01's Avatar
    Join Date
    Apr 2005
    Westerly, RI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I used a Flir E25 infrared thermal camera that I was able to borrow. I posted a few more in my gallery. Can't wait to fly it!
  8. #8
    Join Date
    Sep 2005
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    hi , i got 8500RPM on Zinger 16X6 , 5% nitro , sea level
  9. #9
    Join Date
    Mar 2003
    Vancouver, BC, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Running very rich, with 3 or 4 tanks through it, I got 9600 RPM , APC 16X6
    Malcolm
  10. #10
    RoughLandin's Avatar
    Join Date
    Jun 2003
    Duvall, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Update on the OS 120 AX in the H9 Showtime.
    Amazing engine, still only have about 6 full tanks through it but very happy. I'm spinning an APC 17x6 prop.
    Exhaust report:
    I was using a shortened Bisson muffler specifically made for this engine I then chopped down the expansion chamber about 2 inches to make it fit in the cowl, then narrowed the exhaust diameter to replace the lost of back pressure. With this combo I was getting about 8400 RPM far less than the reported 9200. This combo will hover at about 3/8 throttle and has great pull out even at these lower RPM numbers.
    I then switched to the stock Powerbox muffler with the pitts adapter and immediately got 8900 RPM. I figure this will improve closer to the 9200 as the engine completes break-in phase. The sound is improved (quieter but deeper), at lower RPM it now doesn't have that irritating 2 stroke rattle/ratatattat sound that it had with the Bisson though full throttle does not sound as impressive. I figure the increase in backpressure will help transition performance (still breaking in) but I'm really excited about the extra 500 instant RPMs. I have not flown this combo yet.
    All figures are using 15/15 PowerMaster fuel at sea level.
    I may also try the APC 16.5x5W prop and switch to a plastic spinner to reduce weigh and improve transition performance. How are every one elses transitions, last several engines were 4 strokes which seam a little better in this area... [&o]
    When she comes down, just hope it\'s still under control
  11. #11
    Join Date
    Feb 2004
    Madrid, SPAIN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    New reading
    Mertz wood 16x10
    10% Nitro, 20% syntetic-castor oil
    1800 ft
    RPM 7,550
    Regards
  12. #12
    CGAV8R's Avatar
    Join Date
    Dec 2002
    Hudson, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    8900 with APC 17X6, muffler baffle in, coolpower 20/20, sea level, 90 degrees, 6 tanks through it. I have the idle set at 2250 and the transition is good.
    Aaron D.
  13. #13
    Join Date
    Sep 2004
    STOCKHOLM Akersberga, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    APC 14x12, 10% Nitro 20% oil, peaked @ 9000rpm, richened down to 8700rpm for flights.
  14. #14
    Join Date
    Sep 2005
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ¿ anyone with APC 18x6 ?
  15. #15
    Join Date
    Sep 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I added a four chamber quiet pipe to my 120AX and now it is turning that same APC14x12 @9800rpm[sm=thumbup.gif][sm=teeth_smile.gif] The plane is going like crazy[sm=wink_smile.gif]
  16. #16
    Join Date
    Sep 2005
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    WOW , what pipe do you have ?
  17. #17
    Join Date
    Sep 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have the flatdisk pipe made by the Just engines for the 160-180 engines. It is called "Purple Pipe" but is also available in aluminium finish.
    I forgotten to attach the link to the JE, here it is now.
    http://www.justengines.unseen.org/pipesjen.htm
  18. #18
    Hobbsy's Avatar
    Join Date
    Dec 2001
    Colonial Beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Graupner 15x8, Fox 5% fuel/20% castor=9,475
    Minneapolis Moline G 1350, 585 cubic inches, 141.4 hp, 9.7 GPH fuel use, 4.75 inch bore, 5.50 inch stroke
    CR==15.3 to 1
    Max pull== 14,178
    Front tires==11x15
    Rear tires 24.5x32
    Weight==12,550
    Club Saito member #5
  19. #19
    Join Date
    Mar 2003
    Lincoln, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    APC 16x6 on Powermaster 5% with the new version of the Bisson pitts which has been changed to deliver more pressure to the tank. I got an easy 9600 but didn't want to push it any more. I tuned it to fly at 9200. I would like to try a lighter wood prop to see if I can get closer to a 4 stroke transition but it wasn't bad. Does anyone know what the upper RPM limit of this motor is?
    ORIGINAL: RoughLandin
    Exhaust report:
  20. #20
    Hobbsy's Avatar
    Join Date
    Dec 2001
    Colonial Beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    From the Tower- OS specs. Practical RPM: 1,800 - 9,500
    CR==15.3 to 1
    Max pull== 14,178
    Front tires==11x15
    Rear tires 24.5x32
    Weight==12,550
  21. #21
    Berwyn Bill's Avatar
    Join Date
    Jul 2004
    Berwyn, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    APC 17x6
    Omega 15%
    Stock Muffler
    600' ASL
    8900 rpm
    Best prop I've found yet for my 1.20. The prop-braking on downlines is just about perfect for my taste. Would like to try a 17x6 Xoar though.
  22. #22
    Join Date
    Mar 2003
    Lincoln, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Berwyn Bill
    APC 17x6
    Omega 15%
    Stock Muffler
    600' ASL
    8900 rpm
    Hi Bill,
    I am running a Menz wood 16x6 and getting 10K on 10% with the pits muffler. I find that the spool up is really quick with the lighter prop and the performance is really similar to APC's. I tried Zingers and they were really bad. Do you get a super strong hover pullout with the 17x6. I was going to try it but thought it might kill off too much speed. Wood is definitely the way to go on this engine though.
    If you check out the new OS 200 four stroke it puts out 2.9HP at 9000 RPM. Were getting the same on a much lighter and less expensive engine. I love this thing.
  23. #23
    Join Date
    Jul 2004
    Berwyn, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: rino
    APC 17x6
    Omega 15%
    Stock Muffler
    600' ASL
    8900 rpm
    Hi Bill,
    Rino,
    I like wood props on a lot of my planes but the APC is available at my LHS and not too pricey (club discount is nice too). The hover pullout is astounding on my Fusion 90 (7# 7 oz), Estes rocket-like. With the 17" dia. the surfaces really come alive and it smooths out everything. As far as killing off speed, iot does have considerable braking power but I like that for practicing IMAC and keep my figures smooth and clean.
    I'm sure the Menz is great but the APC is damn good too, wood or not. Spool up on the APC is very nice and overall transition is smooth and linear.
  24. #24
    Join Date
    Mar 2005
    Waterville, NS, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    9,500 dead on, cool power 5%, really owns, apc 17x6, stock muffler, lovin it.
  25. #25
    Join Date
    Feb 2006
    Madison, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Malcolmm--What muffler are you running ???
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
