If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Sep 2004
    STOCKHOLM Akersberga, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Irvine 72 tach readings
    Irvine 72 on a fourchamber flatdisk quiet pipe and a perry regulator VP30.
    Fuel 10% nitro 20% oil halfsyntetic
    Propeller APC 16x6@8500rpm
    This engine is almost new and has only a gallon of fuel through it. Throttle response is fast and the sound is deep, great
  2. #2
    Join Date
    Sep 2004
    Greensboro, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Irvine 72 tach readings
    I have an Irvine 72 with nothing fancy. If you would like I will get prop and thrust data but it may not be what you are looking for.
    Bill
  3. #3
    Join Date
    Sep 2004
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Please write here the prop and thrust data for your Irvine72. I am interested too see how other people are using these beatiful engines.
    Mine is one of the last ones made in the UK. The newer ones are made by OS in Japan, but I dont know if there will be any difference. I hope they dont change the carburetor so much because I really liked them and they work great in combination with a Perry pump VP30.
  4. #4
    Join Date
    Sep 2004
    Greensboro, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sorry it has taken a few days to get the data.
    Irvine 72
    Looks like it has a stock muffler with exhaust extension.
    Prop: 13 x 8 MA classic
    RPM: 9200/9300 RPM
    Thrust: 8# 9oz
    Fuel: 20% nitro
    The engine is on a 4* 60, which does not have a cowl. No attempt was made to retune for maximum RPM since the airframe drag is big and airspeed changes little from half to full throttle. The thrust varied between 8# 6oz to 8# 13oz and settled in at 8# 9oz.
    Notes from a year ago indicate:
    Prop: 14 x 8 MA
    RPM: 8100/8200 RPM
    Notes indicate the prop was changed because the engine sounds better with a 13 x 8. Both props had lots of Hi needle range.
    Hope the information helps.
    Bill
  5. #5
    Join Date
    Oct 2008
    Sheffield, UNITED KINGDOM
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Going back to your comment about using a Perry pump, I have purchased one to use with my Irvine 72 and it states that I should either take vacuum from the centre of the cr4ankshaft cover or through thes ide of the engine case. Can I ask how you have done this?
  6. #6
    Hobbsy's Avatar
    Join Date
    Dec 2001
    Colonial Beach, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Bill, this is an Irvine Q-72 from the mid 80s and it turns an APC 14x6 at 10,000 rpm like most .91s do I run it on Fox 5% fuel with 20% castor. The one with the red head is a Q-40, the Q-40 has the same stroke as a .46 but a .030" smaller bore than the standard 40.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1426548   Click image for larger version.
    Minneapolis Moline G 1350, 585 cubic inches, 141.4 hp, 9.7 GPH fuel use, 4.75 inch bore, 5.50 inch stroke
    CR==15.3 to 1
    Max pull== 14,178
    Front tires==11x15
    Rear tires 24.5x32
    Weight==12,550
    Club Saito member #5
  7. #7
    Join Date
    Jan 2009
    Linden, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi, I have an awesome Irvine 72, and I am using a Perry Pump on another plane. The pump is attached to the engine crank case of a Saito .91 through the backplate. It works great! It adds instant throttle response, and very consistent fuel regulation with the carb. I haven't had any unusual fuel delivery problems with the Irvine engine. However, adding a Perry pump system to this engine might get you a spectacular performing engine with great throttle response. I haven't add the pump to the Irvine because I feel that the increase of performance would me minimal since the engine is one of the best engines I have ever had or witnessed.
    In case it helps anyone, here are some performance readings for the Irvine 72 ABC. Compare these to your 75 size engine!
    Fuel: 15% Cool Power MV (18% syn oil)
    Glow plug: OS #8
    Temp: 55F
    Humidity 39%
    29.92"
    Master Airscrew S-2 15x6@9,500
    Zinger wood 14x10@6500
    APC 14x6@10,000
    Master Airscrew K ser. 13x8@9,900
    APC 13x8@10,500
    Master Airscrew S-2 13x6@10,000
    Master Airscrew K ser. 13x6@11,600
    Zinger wood 13x5@11,100
    Master Airscrew K ser. 12x8@11,100
    Master Airscrew K ser. 12x6@12,900
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
