If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 1 of 2 12 LastLast
Results 1 to 25 of 40
  1. #1
    Join Date
    Mar 2002
    Kannapolis, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    i am getting 7000 on a 22 x 8 Menz with a v-stack 25 gallons of petro
    22 x 8 Menz w/out a stack on a 3.2 3 gallons 6700 RPM
    21 x10 Mejzlik 7500
    21 x 10 Menz 6800-6900
    smooth as silk!
  2. #2
    Join Date
    Jan 2002
    Ponoka, AB,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    On its third gallon.
    No V-stack.
    TNC tach.
    6600 RPM on a Pro Zinger 22x10
    6800 RPM on a Menz 22x10 Std.
    The Menz has superior performance in the air.
    John
  3. #3
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    I got 6000 on a 22x10 pro zinger today, at sealevel and 75*. What mix ratio you guys run? Mine seems a tad low on rpm, got to find out why.
  4. #4
    Join Date
    Mar 2002
    Kannapolis, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    i run amsoil 50 to 1 there is also a amsoil thats made that is required to be mixed at 100 to 1. brison uses the hard clyinders. They told me to prop mine for 6500 to 7500 on the ground when i called them over 40 gallons ago. This made me switched out the following 22 x 10 props that i tried:
    22 x10 rcs maple 6150-6300
    22 x10 futz 6000-6050
    22 x10 menz 6400-6500
    22 x 10 fortes 6250-6350
    Now i only run 21 x 10 or 22 x 8.
    the motor did great on those 22 x 10 props but Brison says i could over work the girl
    all of the above reading were when i had 2 gallons on the motor
    now 40+ gallons
    22 x 8 mezn 7000-7250
    22 x 8 Mejzlik 7150
    22 x 8 Bamula 6930
    smooth as silk!
  5. #5
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    OK, so Im not totally out of line getting 6100 or so on a ProZinger 22x10? With a 3W 20x10 I get about 6750.
    I think there is about 3 or so gallons on it.
    At this point it is pretty weak. Hope it gets better! The Moki 1.8 had about the same pull.
  6. #6
    Join Date
    Feb 2002
    Lakeland, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    Brison 3.2 with standard inline muffler
    MenzS 21X8 = 7600 rpm AMSOIL 100:1
    Zinger Pro 22X8 = 7200 rpm AMSOIL 100:1
    These numbers were verified with two different tachs.
    I bought this engine used but I had it tuned at Brison and I have personally run about 12 gallons through it.
    It is a monster. I prefer the 21X8 MenzS. Makes my DP Extra truly ballistic.
  7. #7
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    holy cow, those are great numbers!! Maybe I need to try some amsoil!?
  8. #8
    Join Date
    Jan 2002
    Ponoka, AB,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    Menz 21x10 "S" @ 7100 rpm.
    Amsoil series 2000 2-cycle mixed as recommended at 50-1.
    Unlimited on my 16.3 lb Sukhoi and some speed too!
    John
  9. #9
    Join Date
    Mar 2002
    Kannapolis, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    what all muffers are we running?
    i am running a J&A Peacekeeper
    smooth as silk!
  10. #10
  11. #11
    JohnVH's Avatar
    Join Date
    Dec 2001
    Ferndale, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    OK, just got done running it again, I tried playing with the timing but found no RPM increase in the little adjustments I did so I put it back.
    I reset the needles to what the book says, then ran it, only get about 6700-6750 on the 20x10 with the first muffler shown in the above links.
    So, I tried that other muffler, man is it loud, my ears are ringing, but it picked up a bit of rpm. Right off the bat of starting it it hit 7100 but then slowed to a bit over 6900 and that is the best I can get out of it now.
    what do you think? Just need more time?
  12. #12
    Join Date
    Jan 2002
    Ponoka, AB,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Brison 3.2 numbers
    Bisson pitts muffler with the pinched ends cut off.
    I think I gained about 100 rpm from this mod.
    The high speed needle is tweaked to max rpm and the low speed needle is as lean as I can go and still maintain a decent transition.
    I do not like running rich......it fouls plugs, makes low power, makes carbon deposits, and can cause rings to stick/seize.
    John
  13. #13
    Join Date
    Jan 2002
    Ponoka, AB,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Brison 3.2 numbers
    Hello,
    More 3.2 numbers
    Same equipment and gas.
    This time at an OAT of +2 degrees C giving me a density altitude of 1000 ASL.
    Beautiful December day!
    My previous numbers were at an OAT of +25 to +30 degrees C giving me a density altitude of 4000 ASL.
    Menz S 21x10 6800 rpm
    Menz S 22x10 6600
    Menz U 22x10 7200
    Menz U 23x10 6200
    Bambula 22x8 6400
    Bambula 22x10 5700
    Bambula 20x10 7300
    John
  14. #14
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have a new one but I need to check my tach reading.
    I am using a 20x8 now, but I know I am underpropping the engine.
    Aircraft Proving Grounds
    http://www.rcaircraft.net/
    Information on the building and flying of Radio Control Aircraft.
    Site for hobbyist in the R.C. Aircraft modeling world.
  15. #15
    Join Date
    Dec 2001
    Naples, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Alright! Thanks John. I've been looking for some rpm numbers on the Bambula 22x8. My Poulan 60 turned mine at 6450rpm and I was wondering how this compared to some of the other motors out there. I know the Bambulas are pretty heavy loads but they sure seem to pull well in the air. This combo should work fine on my Wildhare Edge.
  16. #16
    Join Date
    Mar 2002
    Kannapolis, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    your numbers will get even better with time ......
    smooth as silk!
  17. #17
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am getting 7250 rpm on a 21x8NX propeller with about 1/2 gallon through it.
  18. #18
    Join Date
    Aug 2003
    Wilson, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    From reading this thread, it seems to me that some of the misconception leftover from running glow engines is seeping in here. What you should want is the best performance from your engine running at the lowest possible RPMs pulling and braking like you need it to (propped properly).
    RPM's don't matter worth a hill of beans so long as they are high enough for the engine to be running optimally (full advance). Let's be careful (talking to myself here too because I'm guilty too sometimes even though I know better) about thinking that we want our gas engines turning > 10k RPMs just because our glow engines do. RPMs don't equate to power directly. I guess that's what I'm really trying to say.
  19. #19
    Join Date
    Jan 2002
    Ponoka, AB,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi,
    All engines (glow or gas)develop maximum power(torque) at a certain rpm.
    I try to prop my engines so they turn slightly above that rpm.
    Some experimentation and/or measurement is required to find that out.
    I've been aiming for mid to high 6000's for my 3.2.
    Having said that, the best prop for my engine/airframe/flying style combo might turn at an even higher rpm.
    Horsepower numbers should not be used to evaluate engines since they include the dimension of time in the calculations and is therefore an intangible figure.
    Power, also known as torque, is really the only thing the engine is producing.
    John
  20. #20
    Join Date
    Mar 2002
    Kannapolis, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    i think this type thread helps as folks are breaking in their engine to have a reference and also to trobleshoot those needles h/l.
    smooth as silk!
  21. #21
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    krayzc, I thought you had a 40% plane, what planes do you have your two Brison 3.2's in?
  22. #22
    Join Date
    Mar 2002
    Kannapolis, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    AW Edge and DP Extra. i pulled the brison off the AW Edge last month and gave the plane away. She was a good girl to me 350+ flights. i am looking at the WH Edge as my new plane, however i am keeping my options open. Yes i do have a 40% Radiocraft that thing will outfly any of my stuff it makes any move from IMAC to 3d very very easy and pretty. If not worth me getting rid of my motors so i will have 27-31% planes as long as they keep putting them out, once you have the motor and sevos the planes are the easy part.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	90886   Click image for larger version.
ID:	90887   Click image for larger version.
ID:	90888   Click image for larger version.
    smooth as silk!
  23. #23
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Great shoot. I still have to get up there and fly with you. My Grandma was a little upset I didn't come home for christmas. I have to do it this year, and I plan to bring a plane with me!
  24. #24
    Join Date
    Nov 2003
    metropolis, ANTARCTICA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    There are some good comments regarding this subject. But there are also some important issues to deal with as well
    1) type of prop, thin blade, wide blade,stiff blade etc.
    2) Mfg of the fuel(gas) and the oil as well
    3) ratio of oil to fuel
    4) location of where the engine is run and what altitude.
    5) ignition, magneto or electronic either throttle coupled or auto advance.
    current hp numbers are a numbers game. what you must do is question the mfg of the engine on just how the hp numbers were obtained. with what prop,fuel/mix etc.
    What you want is Peak Torque Horsepower, and the only way to get that is via a dyno.
    As a note, Nicklesil is a trade name for Mahle Cylinders, not the engine mfg.
    Also applies to Sach, Husky and at one time Stihl.
    Use the combination that works best for your specific application.
    I have a 20# Suchoi on a TS52 swinging a 24X8 @ 6100 With a TNC Tach on 87oct @80:1 Amsoil
    And it seems to do everything I want it to do.
    But thats my style.
  25. #25
    Join Date
    Apr 2002
    Locust Grove, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Lets see, I am getting 7250 using an Airwild 21x8nx and a mixture of Amsoil 100:1 and Castrol 2 cycle synth oil. (50:1)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
