Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Saito 65
Reply
Old 04-20-2007, 07:55 PM
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Saito 65
Hi all, I've been playing with a Saito 65. Bought it used, putting it on a 3d 40 size plane. 20% fuel used.
MA14x4K- running strong at 10700 rpm. May have been peaked, but I thought it was running a little fast and didn't want to over rev it.
MA13x5K- pulled 10500 at same needle setting. Again, did not want to lean any further and risk over rev.
APC14x5N- 9980 peaked. This will probably be used for first flights.
MA15x4K- Any one try this one?
Just playing with this engine has maotivated me at the build table!
Any other 65's out there?
MikeB
WMB is offline
Old 04-22-2007, 01:47 PM
P-40 DRIVER
P-40 DRIVER's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Saito 65
Keep the rev's down on that motor or you will blow it up. nothing over 10,000 static on the ground peaked. 12-8, 13-6 works well with that engine but you will need to do some experimentation to find best combo. The 65 has a low red line and a long stroke and a small carb so high rpm's do nothing, pulls real good in the low to mid 9's. Keep it a bit rich too or you will be an unhappy guy as well.
P-40 DRIVER is offline
Old 04-22-2007, 05:30 PM
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks P-40, I was able to play with it a bit more with the APC 14x5N. Richened for flight will get it mid 9's. I had this on a Venus for two flights. I tried the 13x6 and 12x7 then, I think both those props will be way too fast for this new airplane.
Take care, MikeB
WMB is offline
Old 04-25-2007, 09:31 PM
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
15x4K MA 10100 rpm peaked.
WMB is offline
Old 10-27-2008, 07:24 PM
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Playing with this one again. I put a new ring and cylinder on and cleaned the valves.
10% with a little caster added, 65 degrees, APC 13x6, 14 oz through engine
9800 rpm
I am going to put this on my 4*40 just for the heck of it.
WMB is offline
Old 01-01-2009, 08:14 PM
w8ye
My Feedback: (16)
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Had a Saito 65 for several years It ran the APC 13-6 at 10K with 15% Rich's Brew
w8ye is offline
Contact Us Archive Advertising Cookie Policy
