Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
OS 1.08 davis diesel conversion 18x8
Reply
Old 05-22-2007, 09:02 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS 1.08 davis diesel conversion 18x8
Just ran my OS 1.08 diesel conversion (Davis) not even fully broken on and turns a ZOAR 18 x8 at 6500 what caught my eye was the number on a G-26 16 x8 7000
I expect it will hit 6800 no problem went from 5800 to 6100 to 6300 and finally 6500 with only about 15 minutes on it that is a pretty serious number for a 1.08 OS martin
AMB is offline
Old 05-24-2007, 07:51 AM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS 1.08 davis diesel conversion 18x8
what were your rpms on glow?
pe reivers is offline
Old 05-24-2007, 08:47 AM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pe at the time I only had a 15 x8 and ran just to check out the the engine, battery went dead on the tach so could not get a read I think that is the recommended prop for glow , got the engine "bare" used no box no info sheet , the conversion seems right up there with a a gasser SPE 26cc gas review AJ Coholic 6960 wood zinger idle 2000 mine idle 1350
it needs a little more time most likely will pick up an other 400 with a little time on it martin
AMB is offline
Old 05-24-2007, 03:55 PM
rustypep
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What type of application could you use this in? I am getting more and more curious about diesel. Thanks!
rustypep is offline
Old 05-24-2007, 05:40 PM
AMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rusty pop over tothe diesel site now will reply there thx martin
AMB is offline
Contact Us Archive Advertising Cookie Policy
