Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Enya .61CX
Reply
Old 07-03-2007, 01:04 AM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Enya .61CX
These figures are quoted directly to me from Mr Enya himself.
The performance of .61CX TN
Propeller 11.5 x 8 APC
Revolution 10,400~10,500 rpm
Fuel nitro 15% oil 22%
Bear in mind that this is a .61 motor in a .40 sized case and weighs just 380gm (13.4oz) without muffler. The Muffler Enya Supply weighs in at 124gm (4.4oz)
CustomPC is offline
Old 07-04-2007, 09:44 PM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Enya .61CX
From another thread.
ORIGINAL: LaCerne
...... I've run 3 tanks of 10% nitro with 18% castor synth blend + 3oz castor added per gallon: APC 12X6 hold about 10800 with a steady 2200 -2400 idle. The carb is a 2-needle carb plus an airbleed for idle trim. This seems to be a good combination for getting a good mid-range and idle. Need more time on the engine before it's locked in. So far, so good!
CustomPC is offline
Old 07-22-2007, 04:35 AM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My motor is now averaging 10,800rpm with a Bolly Clubman 12.5x6 prop.
Fuel used is 10% Nitro, 15% Klotz and 5% Castor.
CustomPC is offline
Old 08-29-2007, 02:59 PM
RVman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Custom, i just finished breaking in my 61cx. It peaked at 10, 500 with an APC 12-7 and runs very smoothly after 60oz of fuel. Idle is at a very low 1800-1900 and transition and midrange are excellent. The build of this thing is really high quality, looks like it should last a very long time.
Today was very humid and hot (40 celcius with humidex) so i expect to hit 11K+ when the weather cools down and the engine gets some more time.
RVman is offline
Old 08-30-2007, 06:17 AM
NM2K
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: RVman
I'd like to see how it fares with larger diameter, low pitched props as used for 3D flying.
I have a Funstar 3D and a Harrier 46 NIB in the garage. If I can get to one of them soon, I'm going to fit the .61 in the nose. Should be a piece of cake, being in a .40 sized crankcase.
Ed Cregger
NM2K is offline
Old 08-30-2007, 01:01 PM
RVman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry can't help on that one, the plane can't take more than a 12" prop. A 12-8 K series masterairscrew was turning 10500 today in dryer and cooler air.
RVman is offline
Contact Us Archive Advertising Cookie Policy
