Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
mvvs 49 with tuned muffler
Reply
Old 07-19-2007, 06:29 AM
asmund
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default mvvs 49 with tuned muffler
Today I tached my 49 running 5% nitro 15% synth oil and APC 12-4. All leaned out it produced 14200 rpm which is 200 more than last time I tached it, I guess it is fully broke in now after about 3 gallons. I`m very impressed with this number and it actually passes my tuned ASP 52 XLS, if only barely
asmund is offline
Old 08-14-2007, 10:42 PM
Razor-RCU
Razor-RCU's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: mvvs 49 with tuned muffler
The MVVS-49 is a monster, especially in the torque category- That is a REAL good number for 5%
I gotta try one of those...
Razor-RCU is offline
Old 09-24-2007, 12:42 PM
Hercmate
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just broke my MVVS 49 with Genesis Throttle Pipe in this weekend. The prop is an APC 12.25x3.75 and whilst I didn't get any figures the spool up was quite sluggish (to be expected I s'pose!) Fuel is ProSynth 5% but it's only had 1/4 gallon through so far.
Has anyone got any tacho numbers on this prop?
Hercmate is offline
Old 09-24-2007, 01:11 PM
asmund
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi, I get 13600 rpm at peak on that prop on my 49. The slow spool up on that heavy prop is the reason why I went to the APC 12-4 instead as it spools up much quicker.
Also make sure you have leaned out the low end needle enough, otherwise the transition will be very sluggish no matter what
asmund is offline
Old 09-25-2007, 02:29 PM
Hercmate
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great stuff, thanks Asmund
Hercmate is offline
Old 09-25-2007, 02:36 PM
asmund
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your engine will develop more rpm`s and power after it has been running for a couple of gallons. Mine has become stronger and stronger the more I run it.
By the way, it would be really interesting to hear what rpm`s you get on the 12.25-3.75 using that Genesis throttle pipe, when and if you have some tach readings
asmund is offline
Reply
Display Modes
