Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
a tach thing, ever heard this before ???
Reply
Old 09-10-2007, 04:43 PM
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default a tach thing, ever heard this before ???
hey, though my tach was bad,,
my H9 DVT tach was always spot-on with all other brands of tachs I tested it against,, well the other day my tach didn't read right, numbers were all over the place (will I knew I had to send it back, eerrrr),, well then I thought "the sun was coming down and the tach was pointing right into the sun", so I turned the tach so it was pointing away from the sun and it worked great,,
anyone ever heard of this before ???
Jim
the Wasp is offline
Old 09-10-2007, 05:05 PM
krayzc-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: a tach thing, ever heard this before ???
so far all i buy is ragie tach s
krayzc-RCU is offline
Old 10-26-2007, 02:17 PM
YBP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine┬┤s like this too.
I think this is nothing to worry about. I believe the sunray┬┤s can mess with the sensor readings.
Mine is spot on when checked against a lamp plugged in the wall outlet.
Lars.
YBP is offline
Old 10-26-2007, 07:21 PM
broke_n_bummin
broke_n_bummin's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't know the differences in all the tachs out there, but almost any tach that used reflector tape will do that when pointed into the sun.
broke_n_bummin is offline
Old 11-01-2007, 11:16 PM
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
broke_n_bummin,, I can see the light now LOL
well I have never seen this happen at the field, so what I'm now think happened is,,
I had the motor mounted to a picnic table under a 2nd floor porch-deck, under the deck it was a bit dark, the sun was located directly in front of the prop, so it was dark behind the prop, so with the tach behind the prop the tach had no reflection on the prop to read,, as I said I have never had this happen at the field where there is sun on both sides of the prop..
Jim
the Wasp is offline
Old 11-02-2007, 07:24 AM
broke_n_bummin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I met up with a guy a few months ago that wouldn't own an optical tach. He's rather hold his tach to the point of his spinner. He was convinced that the optical tachs couldn't be reliable. I observed his technique, and... well ... I think he needs to contact Sylvia Browne to see what he was in his last life, and just how long it lasted. It wasn't too bad up to about 7K ... then it started wabling and vibrating. When it did that, he'd just apply more pressure. After I saw 9K, I couldn't watch anymore. All that kept running through my mind was that joke about a Rednecks famous LAST words. " Hey Y'all ... Watch this"
Optical tachs are pretty sensitive and fairly accurate. I have found that if I put my tape on the spinner and hit it at an angle I don't get as much variation caused by different light sources. Most of the time I use the one we have at work. I'll have to get back to you on the brand, but it's an industrial model with 2 lasers that constantly check against themselves. They have it calibrated twice a year, and so far this year all it has measured is rpms on my engines. I have tried to make it mess up with the light and couldn't. I'll try your method tonight and see what happens. We have some UV lights I can use to duplicate sunlight. The people we bought the tach from sent us a card wanting to know if it ever messes up, what the conditions were and what it did. So far, the other equipment we've bought from them has been nothing but the highest quality (infared heat guns, pyrometers, spectrometers).
I have a Raytech tach that I use here at the house, and in order to get it to read right, it has to be a certain day of the month, the planets have to be alligned just right, and you have to recite an incantation while burning insence.
Reply
Display Modes
