If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 20 of 20
  1. #1
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    YS 1.40 sport rpms with 16" and 17" props.
    Does anyone have any numbers for the YS 1.40 Sport.
  2. #2
    Join Date
    May 2007
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: YS 1.40 sport rpms with 16" and 17" props.
    I am turning ~9000 with an APC 17X8 using YS 20/20.
  3. #3
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I glad somebody posted. Have you ever tried the APC 18-6W on 20/20. I have been debating if I want to run 20/20 or 30% Helicopter fuel. The Yak 54 that the 1.40S is in weighs about 10 lb's even.
    Also, have you tached a APC 16-10 or any other props, and how much time do you have on it.
  4. #4
    Join Date
    May 2007
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I have tried the 18-6 pro zinger and wasn't impressed, the APC would only be worse due to the weight increase. The motor really sings on the 17X8. BTW, I am using it on the QQ YAK 54 coming in at a hair over 11lb. Pull out is there but not great, you sould be fine at 10 lb. I do try to limit the use of full throttle because 9000rpm is at the top of the RPM band recomended by the manf.
  5. #5
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Why are swapping out the YS? Mine is in a Aeroworks Yak. What % of throttle does it take to hover your 11 lb Yak?
  6. #6
    Join Date
    May 2007
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I would say 65% to hover.
    I am swapping the YS for a brillelli 26 (gas) because of the price of glow and the rate at which the YS uses it (1 gallon a week for me).
    My YS is only a couple of months old. It is by far the best running glow engine I have ever owned. If it didn't drink so much fuel I would keep it around.
  7. #7
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    N7160F,
    I understand your decision. I do not mind the glow fuel one bit. I like the perfromance that only GLOW can give in these size planes. There is such a weight penalty to go gas in a 10 lb plane.
  8. #8
    Join Date
    May 2007
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am going with a Brillelli 26. I am expecting to get 9000 rpm with a 18X8. with only a 6oz. weight penality. Worth it.
  9. #9
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    N7160F,
    For me there would be alot bigger weight penalty than that. I am only running the old style YS stainless header pipe. It only weighs 1 OZ. My engine weighs 35 oz bolted to it's lightened aluminum mount. There would be allmost 10 OZ plus the ignition battery and switch harness.
    Why did you not like the APC 18-8W, was the spool up very slow (heavy). What rpm did it turn it? I reweighed my plane last night, and it is 9lb 11 oz.
  10. #10
    Join Date
    May 2007
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: MOTORMAN37
    N7160F,
    With the PZ 18x6, the breaking action of the prop was too high and the pull of the prop was less than with the APC 17X8. When I tried the APC 18X8W the motor was loading up too much (ie max rpms too low).
    If you are running %30 nitro the 18X8 would probably be the way to go. I would look for a Xoar or other wood prop though, the APC's get really heavy over 17".
  11. #11
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    N7160F,
    PZ prop? I am talking about the APC 18-6W not a 18-8. If I run 20% instead, what props do think compare to the APC 17-8 for a little more load and a couple hundred less rpm. I hope to run it in the 8500-8600 range. What was the best set up you found, and what muffler did you use?
  12. #12
    Join Date
    May 2007
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Motorman,
    PZ = Pro Zinger.
    I don't have any expirence with the APC 18X6W. I think it will work well for you since your plane is significantly lighter. The breaking effect is not that bad once you get used to it, it actually helps when doing 3D.
    As far a mufflers go. I started with the stock muffler. When that fell apart in the air, I was using a straight pipe out the side of the cowl. I am now running a performance specalities cigar type muffler. Of the three I didn't notice any performance differences.
  13. #13
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    N7160F,
    I really like the looks of the Zoar props, but I have never heard how they compare. All I can do is sit here and dream about flying, since it is still -8 @ noon here is WI. Another couple days, and the finsihing touches will be done on the YAK, and then I get to start the Funtana X100 with another YS. Then I have two other YS's that still need a home.
  14. #14
    Join Date
    May 2007
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    the Zoar props are also extremely light. Almost half the weight of the APCs.
  15. #15
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I would like to try one this summer, how do they compare load wise? What rpm's did you get with PZ that you mentioned a few posts ago?
  16. #16
    Join Date
    May 2007
    League City, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Motorman,
    I was getting ~8600 with the PZ 18X6. But the pullout seemed to flatten out in the higher rpm ranges. I don't know if the prop was physically deforming or not. I have heard the Zoar props are significantly better than the PZ props. I am going to try an 18X6 on the 26cc once I see what rpms are with the 18x6 PZ.
    I am also going to try the 22X8 on the DL50 that I have. I am just waiting on the 26cc to get here so that I can order the two props together and save a little on shipping.
  17. #17
    Join Date
    Jun 2007
    Lakeland, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Guys, I'm seriously thinking of getting a YS 140 Sport to power a 15lbs (w/motor) 72 inch KMP Seafury. Is this enough motor, currently powered by an RCV120SP that is barely enough power to tote it around the field at full throttle.
  18. #18
    Iflyglow's Avatar
    Join Date
    Oct 2002
    Clintonville, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It would pull it very good. Allmost identical if not a little edge on the Saito 1.80.
  19. #19
    skiman762's Avatar
    Join Date
    Dec 2005
    Nashville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think at that weight I'd be looking at a gasser maybe a Brillelli 36 at least it won't guzzle 30% nitro by the gallon
    plus you could run a nice 3 bladed prop too
    land of the FREE: you\'re free to get a JOB not a handout.
    home of the BRAVE: they paid for it and you\'re enjoying it
  20. #20
    Join Date
    Jun 2005
    Abingdon, VA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Your going to get better throttle response from the Xoar but dont be suprised to see your peak drop even compared to the W. About a 2ounce diference form the 18x6w and the Xoar 18x6 swords.
    and Btw Im getting a solid 8700 peak on the Saito 1.80 with the Xoars on 15% will try 30% as soon as the weather makes it mind up.
    More info on Saito\'s http://saito-engines.info/
    Club Saito #542
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
