Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Magnum .15 XLS
Reply
Old 01-11-2008, 04:52 PM
microsprint9
microsprint9's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Magnum .15 XLS
2 brand new Magnum .15XLS engines, 3rd 4oz tank of 10% omega fuel, 8x3 MA combat prop
18200rpm on both engines ( still a little bit rich ), will try to get more tomorrow.
microsprint9 is offline
Old 01-23-2008, 10:06 PM
buzzard bait
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Magnum .15 XLS
Wow!! If you try it with a higher prop load please let us know. Is this an engine that is only happy when its screaming, or can you load it up? I'd be curious how it handled an 8x5.
Thanks for the report.
Jim
buzzard bait is offline
Old 01-26-2008, 11:08 AM
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you have an APC 8x4 to try. My Mag 15xl gets 14,800 with 30%.
WMB is offline
Old 01-28-2008, 12:30 AM
foresterxt
My Feedback: (35)
foresterxt's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just for reference, I'm getting 14,000 on my FP .15 with an unbaffled muffler running an APC 8x4 on Omega 15%. If you get a chance, please try the APC 8x4, I'd love to know what you get. I've been thinking about getting one of the xls .15s.
foresterxt is offline
Old 01-29-2008, 10:00 PM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually i've heard the XLS doesn't mind a higher pitched prop, i will try it next time i go to the shop but my XL would turn an APC 8x4 at 15000 on 10% omega and a A3 plug, the XLS is stronger than the XL so i will see, i have lots of 8x4's at the shop.
I wanted the 8x3 to get the most thrust and speed wasn't an issue as this engine was for my combat delta found in post #3 http://www.rcuniverse.com/forum/m_6960015/tm.htm
Old 02-08-2008, 09:50 PM
RocketRob
RocketRob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
also not a bad idea to run it in with a lighter load
RocketRob is offline
Old 02-09-2008, 03:37 PM
microsprint9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well i tried an APC 8x4 and it was 15000rpm on 10% omega, my friend broke his last 8x3 prop and subbed in a MA 8x5, on the ground got 13700rpm on 10% omega but in the air it was faster than my screaming MA 8x3 and the engine didn't seem to mind the extra load and was much quieter in the air.
Contact Us Archive Advertising Cookie Policy
