Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
OS MAX H80 /R.C. 1971 W BISSON LOW NOISE MUFF
Reply
Old 01-27-2008, 05:00 PM
griesel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS MAX H80 /R.C. 1971 W BISSON LOW NOISE MUFF
OS MAX H80 /R.C. 1971, with Bisson low noise muffler. With MAS S2 Scimitar 13x6 propeller 10000 rpm.
This was with about 500 rpm rich setting. The engine was definitely not fully broken in as it has two rings
and was near the end of a third tank of fuel when it was measured. The two plugs were OS#7 and the fuel
was 5% nitro, 25% oil made by mixing 2 oz of castor oil with 30 oz of 5/20 Byron fuel.
griesel is offline
Old 06-12-2008, 07:44 PM
Broken Wings
My Feedback: (20)
Broken Wings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS MAX H80 /R.C. 1971 W BISSON LOW NOISE MUFF
They're neat engines, I've got a couple of them. Your engine probably has a needle bearing in the big end of the connecting rod. Just for kicks I mounted a Rev-Up series 2 Special Pro 16x41/2 and i could read the letters on the prop at idle...
Broken Wings is offline
Contact Us Archive Advertising Cookie Policy
