Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
YS 1.40 Sport RPM?
Old 04-29-2003, 12:56 PM
lnorris
Default YS 1.40 Sport RPM?
Anybody out there running a YS 1.40 Sport yet? If so, what RPM are you getting out of prop + fuel?
Also how big of a fuel tank are you running?
Old 06-18-2003, 10:32 PM
lnorris
Ok, I'll guess I'll just answer my own question.
YS 1.40 Sport (brand new, 20oz burned)
25% Ritches Brew
86 degrees F, 50% humidity
Central Oklahoma elevation (whatever that is)
APC 17x8
8550 RPM
I'm expecting a few hundred more when broken in.
Old 06-19-2003, 01:11 PM
Sprink
Sprink's Avatar
I hope you do get more than that, I get about 8500 with an APC 17x8 on my 120 FZ, using 15% coolpower. Hopefully you are at an altitude in Oklahoma, I'm near sea level.
Old 06-19-2003, 01:27 PM
lnorris
I do too. I was hoping that by posting this I'd get a flurry of "That's LOW. On my YS 140 Sport I'm gettting way more RPM (XXXX) with a XX/X prop"... Guess most YS 1.40 Sport owners don't own tachs....
And remember it's not broken in and still running pretty rich. I have almost had to close the regulator (3/4 turns from fully seated) to get it to idle so I've just begun to tune. That and Ritches Brew is down on the nitro so I'd probably get a few hundred RPM going to Cool Power...
Just checked and we are at 1285 ft elevation..
I'll continue tuning and post what I get once it's broken in.
Old 07-21-2003, 12:51 AM
edgeguy
My Feedback: (16)
YS120FZ.
MEjzlik 16X8
Powermaster 30% nitro 23% low viscosity oil
6200 feet elevation
85 degrees
40% humidity
9800rpm
