Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
How to check tachometer calibration
Reply
Old 04-04-2008, 08:42 AM
mrbassman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How to check tachometer calibration
Just something to contribute that I learned.
If you want to make sure your tach is operating correctly, set the prop choice to 2 blade and hold it up to a flourescent light. It should read 3600. That's because here in the US, our electricity runs on 60 cycles per second. Multiply that by 60 seconds, and you get 3600.
If it doesn't read 3600, your battery is getting weak or your power company is not up to par.
I may be wrong here, but I believe in England and the rest of Europe, they run on 50 cycles per second, so their tachs would read 3000.
Don't try to tach your engine anywhere near a flourescent light.
Just trying to give back for all that I have learned.
Peace.
mrbassman is offline
Reply
Display Modes
