Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Thor 45 with Zoar 20x8
Old 08-21-2008, 10:14 PM
sevans16
Default Thor 45 with Zoar 20x8
OK I bought this engine in a ready to fly plane that was never flown. It has 4 tanks of fuel through it, still running the rich oil mixture for break in. LawBoy ashless (32-1). Aftermarket wrap around pitts muffler and has the velocity stack on it.
I am locate in Sunny Las Vegas and temp outside was around 95 degrees. I am not sure how the numbers compare but here they are
Zoar 20x8 max rpm: 7100
Old 08-24-2008, 07:00 PM
sevans16
Default RE: Thor 45 with Zoar 20x8
I have a little over a gallon on it now. Running better. I also cut down the velocity stack which seemed to improve things. I will post updates after a get 3-4 gallons through it.
