Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Fuji BT 24A
Reply
Old 11-11-2008, 02:22 AM
d7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Fuji BT 24A
Engine setup stock. 2 gallons fuel through it, tuned for flight running 40-1 Troy-Bilt senthetic.
Top Flite 18-6 Wood 6900
Xoar 17-7 Wood 7000
MAS 16-8 Wood Scimitar 7100
MAS Nylon 18-6 Clasic 6150 Heavy prop for this engine.
Will try a wood 18-8 next but I don't have one yet.
Pat
d7 is offline
Old 11-11-2008, 04:25 PM
richgrow
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Fuji BT 24A
[:-]I've Got this engine on Carl Goldberg 67" YAK 54. Flew a few Flights with APC 17 X 6 Prop. Going Try APC 16 X 7 or 16 X 8 see if I get Unlimited Vertical and faster engine spoil up. Engine has Great Power and I Just Need Dial in the Prop for this Airplane. Did You do any Thrust measurement? What Airframe You Flying it on? I haven't Tached Mine since it had Great Thrust on the Ground. Climbing Straight Up is where see how well that Prop Pulls and also Hovering and pulling out Hover.
richgrow
richgrow is offline
Old 11-11-2008, 05:23 PM
d7
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The engine lives in a BUSA 1/4 scale Fokker Dr1 that weights 15 Lbs. It flys very well with a TF 18-6 prop. A MAS 17-8 scimitar did OK but the 18-6 seems to fly better. Have not done thrust testing.
I have played with a Performance Calculater on line that says a 18" prop at 6900 it good for about 13Lbs thrust.
Pat
d7 is offline
Contact Us Archive Advertising Cookie Policy
