APC prop change...
APC prop change...
Hi,
Wow, I just changed from an 11 x 7.5 Master Airscrew that I had on my Fox Eagle .61 for break in, to an APC 12 x 7. I gained almost 2 lbs. of thrust!! Amazing! I can't wait to fly it again. (It tached around 10500 with the APC, but I think this will improve with more running as this is a ringed engine with very little time on it.) How much of an increase in power do you guys notice after a ringed engine gets really broken in?
This analyzing props/engines is fun and there is definitely a lot to be gained. If you don't have them, get a tach, a scales, and start experimenting! The various thrust/horsepower programs are interesting to play with as well.
AV8TOR
AV8TOR
