If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 25 of 25
Thread: Magnum 52 xls
  1. #1
    Join Date
    May 2003
    Caroline, NB,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Anyone else have any numbers with this motor?
    So far on my 30 minutes old engine i've tached it at 14200-14300
    on 10% nitro w/APC 10-6,stock muffler w/baffle still in for now.
    How is that so far?
    Off to balance an 11-5!
    Steve
  2. #2
    Join Date
    May 2003
    Caroline, NB,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    11-5 APC @13100 still rich.
    I'm at 2900 ft ASL.
    Will try tommorrow without baffle.
    I think this one's gonna be a good one for my super sportster,Finally.
    Steve
  3. #3
    Join Date
    Sep 2002
    Meridian, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    15,500 with a 10x6, baffle in, 2900 ', on a hot day. After 3 tanks of fuel, and 5 flights, it idles well now. Just can't get it to shut down. I close the throttle ALL the way, and she keeps on running........
    Also, tried running it without the baffle, and it wouldn't run at low and mid RPM's without getting air bubbles in the line. Not enough pressure, I would guess, for the heighth of my fuel tank relative to the carb without the baffle.
    Seems like a VERY strong engine, however!
    Kmo, dirt bikin\', airplane flyin\', Harley ridin\', snowmobile ridin\', Duramax drivin\' fool........
  4. #4
    Join Date
    Jan 2002
    OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum .52 XLS
    Why are you guys using a .40 size prop (10-6) on a strong .52?
    Just like to hear em howl eh?
    RJ
  5. #5
    Join Date
    Sep 2002
    Meridian, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Because the instructions SPECIFIED a 10x6 prop for break in. It's now turning a 12x4, for 3D flight. I normally run an 11x6 on my .46 FX for sport flying, and a 12x6 on my .61FX, all APC props.
  6. #6
    Join Date
    Jan 2002
    OR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Now that sounds more like it.
    RJ
  7. #7
    Join Date
    May 2003
    Caroline, NB,
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Hi,Sled.
    What kind of fuel are you using?
    No,i'm not worried i got a dead horse out of this little gem!
    I've since put it in my old fun flyer and can say nothing but;exxxcellent!
    What were you saying about a 10-6 makin' this thing What? did i hear that right "growl"
    Sing to high heaven would be a more suitable way to convey this message.That is as recommended!
    After break-in i went 12.25x3.75.
    Sorry haven't tached it with that one yet.
    But did run a Bolly 11.5x6 on 10% and man i'm just not used to landing that fast with a super aerodynamic super sportster,crosswind yet.
    This motor and all the wonderful people here at RC sure have helped me take this "awsome hobby" to new heights.
    Till i can fly and post again.
    Steve
  8. #8
    Join Date
    Oct 2002
    Land O Lakes, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    sledman - You have an air leak in your carb. A baffle has nothing to do with bubbles in your fuel line. With the baffle you have more pressure which masks some of the problem. If your engine is running with the barrel closed it has to be getting air from somewhere.
    Adrian Martinez
    ADS 400Q FPV Quadcopter
    Multiplex TwinStar 2 FPV
    Monkeyblunt Popwing FPV
    HobbyKing Skyfun FPV
  9. #9
    IronCross's Avatar
    Join Date
    Aug 2002
    NearBy, AZ
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Does not sound like this engine is all that impressive. An OS .46 with a 10X6 APC will hit an easy 16K. Usually run a 9.5X7 at around 14.8 - 15K for racing. I would expect a little more out of a .52
    Inside every older person is a younger person wondering what the hell happened
  10. #10
    Join Date
    Sep 2002
    Meridian, ID
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Not in Idaho, in the summer. The temperature and the altitude together create what is called "Density altitude". As I type, I just called the Boise airport and got the pilot's weather report. Density altitude, at 4:32 Mountain time is 5,400 ' ASL. That is lower then it has been. It's been between 5,500' and 6,000' recently. Believe me, that affects performance in ANY engine, and 2-stroke engines are affected more than 4-stroke engines. AND.....the smaller the displacement, the more they are affected. This .52 DEFINEATELY out performs, and is stronger, than my O.S. .46 FX. Not that the FX isn't a great engine, because it is. So is my O.S. .61 FX. They ALL run better when it's cooler out, though.
  11. #11
    Sport_Pilot's Avatar
    Join Date
    Jan 2002
    Acworth, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Bubbles in the remote needle are usually not air! Think about it if the tank is under pressure and you have a leak the fuel leaks out, the air doesn't leak in. Air bubbles in the remote needle are usually caused by the drop in pressure across the needle causing a small amount of fuel to vaporize. Sometimes raising the tank pressure will help. Often there is no bubbles at idle but bubbles occur at higher speeds, this is because the higher fuel flow causes a higher pressure drop accross the needle. Unless the bubbles are very large they are not a problem. Also bubbles are more likely to occur at higher temps and altitude.
    Glow Head Brotherhood #15
  12. #12
    Join Date
    Oct 2002
    Land O Lakes, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Thanks for the onfo about the needle but what about running with the barrel closed?
    Adrian Martinez
  13. #13
    Join Date
    Jan 2002
    Acworth, GA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    Adrian,
    Probably an air leak through the front bearing, carb base, idle needle, barrel, or backplate. The backplate is the easiest to fix, but often overlooked, on a lot of overseas engines the screws are often not tightened enough.
  14. #14
    Join Date
    Dec 2002
    little rock, AR
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Magnum 52 xls
    You can find your air leak by placing a hose on the air intake dunk the motor in alchol and pressureize the motor make sure the piston is at the eshaust port you can check the needle valve the same way just take it off the motor
    luck is when prepartion meets opportunity
  15. #15
    Join Date
    Feb 2004
    apple valley, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    Magnum 52
    YS 20/20
    Mac's one piece muffler/pipe thingy
    APC 12 x 4
    14.2k rpm
    About 600 feet and 40 degree day.
    Damn, did YOU see where it landed (#$@$)
  16. #16
    Join Date
    May 2006
    CAMDEN, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    XLS 52
    9x8 prop
    macs header with mousse can muffler
    16,410 rpm
    I still have more to gain by taking a little more off of the header but for now it is good. I am very impressed with the power of this motor.
    Kevin
  17. #17
    Join Date
    Nov 2005
    Floroe, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    Mag 52, APC 12,25-3,75= 13700 rpm. APC 12-4= 14100 rpm. Tower muffler fitted and some tweaks
  18. #18
    DALE PABAJO's Avatar
    Join Date
    Sep 2002
    san lorenzo, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    .52 XLS USEING COOL POWER 30% HELI,11X6 APC & O.S.#8 PLUG,TACH READING 14.000
    WWW.LAGRARAMBETA-AEROBATICS.ORG
  19. #19
    Join Date
    Sep 2002
    san lorenzo, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    GONNA TRY AN O.S. .46 MACS PIPE MUFFLER AND AN 11x8 MAS. WOOD PROP. ???
  20. #20
    Join Date
    Nov 2005
    Floroe, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    ASP xls 52, Tower muffler, small portjob on the sleeve, 30/23 helimix, APC 12-4= 14700 rpm Mucho power, throttles perfect and flies my Katana 3-D profile
  21. #21
    Tiroloco's Avatar
    Join Date
    Jul 2004
    Mexico city, MEXICO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    Magnum XLS-52, mirror like polished combustion chamber, O.S. 40J Carburator- O.S. 50 SX-H Hyper crankshaft, K&B Glowplug, Boca ceramic bearings, Tower hobbies muffler and some port tweaks, 14200 rpm with an APC 12.25X3.75 prop, powermaster 15% nitro heli fuel.
    4800 feet ASL, 75F.
    Best regards.
  22. #22
    Join Date
    Aug 2004
    Louisville, KY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    This engine was not run for 3 yr's, last flight was gopher hole crash of edge 360 (oops, &^*$ thumbs),Today mounted on test bench with old 10% wildcat. 10x7 master airscrew prop cut down to 9.75 dia and balanced. pressure altitude approx 500', temp 87F. peak RPM 16K with about 400F cylinder head temp. Best normal full power adjustment looks like 15500 RPM with about 360 degrees F cylinder head temp. I make that about 1.65 HP at normal needle adjustment, with 1.8 possible.
  23. #23
    Join Date
    Nov 2005
    Floroe, NORWAY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    a MAS 10-7 at 15500 rpm is consuming 1.34 hp, how did you make it 1.8 hp?
    My piped XLS 52 is turning APC 8-8 at 19200 rpm and I have only just begun cutting the header
  24. #24
    Join Date
    Sep 2009
    , MO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    Has anyone had any exp. with a pitts muffler  on the xls 52. I could use some help...thx..
  25. #25
    Eganwp's Avatar
    Join Date
    Jan 2008
    Calgary, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Magnum 52 xls
    Mine pulls exactly 300rpm less than my OS 55ax. 13,900rpm on a 10x8 APC on 10% Omega.
    35% H9 Extra 300 - DLE-111 | 33% Lanier Yak 54 - DL-100 | 30% Peak Edge 540T - DLE-55 | SkyWalker Long Range FPV
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
