Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
OS FGR Blackhead vs Webra 10ccm Blackhead
Reply
Old 01-19-2009, 01:14 AM
rainedave
rainedave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default OS FGR Blackhead vs Webra 10ccm Blackhead
As soon as the weather warms up I'll pit these two against each other.
Just for fun (and historical accuracy) I'll test with Top Flite Super-M 11x7, 11x7 1/2, 11x7 3/4 and 11x8 props.
Will the Webra win on all four props?
David
ID:	1114178   Click image for larger version
rainedave is offline
Old 02-01-2009, 04:43 AM
DerFly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: OS FGR Blackhead vs Webra 10ccm Blackhead
Sweet! That'll be a nice comparison. I have both those engines so might also do a back to back and see what we get.
The Miss Norway build article available elsewhere notes that the Webra is just a little stronger than the FGR. I wonder if that's correct!
Nice collection of props too.
DerFly is offline
Old 02-09-2009, 10:32 AM
rainedave
rainedave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got a chance to run these two engines yesterday. Unfortunately, the battery in my tachometer went dead before I could complete the tests.
The last time I ran the Webra I was not happy with the transition. This time I added an extra head shim (total of two) and used a new Fox Gold RC Long plug. Wow. The transition is as instant as any of my new OS's. I can let it idle for a few minutes and it will go to full throttle without any hesitation or coughing. Very quick and smooth. So, if you have an old Webra with the early TN carb, try my remedy.
Webra Blackhead. Stock muffler. All props OOP Top Flite wood Super-M's. Powermaster GMA 5/22. 65° and clear.
11x7 - 11,691 - 1.2hp - 7.2lbs static thrust
11x7.5 - 11,406 - 1.19hp - 7.16lbs static thrust
11x7.75 - 11252 - 1.18hp - 7.11 static thrust
11x8 - 10,861 - 1.09hp - 6.76lbs static thrust
What is interesting is that in a magazine ad from 1970 Webra claimed 1.72hp per cubic inch. Multiply that by .61 and you get 1.05hp. That was either a conservative rating or my engine is on the strong side.
I will test the OS FGR next to see how it stacks up. Stay tuned.
David
Old 02-09-2009, 12:28 PM
stg61abc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi Dave, i put my 10 cents on the Webra !!! hehehehehe..... lets wait for the FGR numbers
stg61abc is offline
Contact Us Archive Advertising Cookie Policy
