Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Testors/McCoy rotary valve .049
Reply
Old 03-14-2009, 09:31 PM
jeffie8696
jeffie8696's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Testors/McCoy rotary valve .049
Running Byrons 15% and a Tornado 6X3 it turned 14,000 but I think it needs more nitro to be happy.
The compression on this piece seems low. Easy starter though.
jeffie8696 is offline
Old 05-08-2010, 03:41 AM
Lost Glider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Testors/McCoy rotary valve .049
Is this a reed engine?
Lost Glider is offline
Old 05-08-2010, 07:16 AM
Jezmo
Jezmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glider, the title says "rotary valve .049" so no it's not a reed engine.
Jezmo is offline
Old 05-08-2010, 10:09 AM
jeffie8696
jeffie8696's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 05-11-2010, 03:18 AM
Lost Glider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Jezmo
Glider, the title says ''rotary valve .049'' so no it's not a reed engine.
I'm just proving that I'm human by misreading or overlooking the title line.
Looking over some notes I took on 10 of these engines, one turned 14,400 the others were all in the 13,000 range. I think I was using 15% fuel, and a 6x3 prop, don't know what brand.
Old 05-11-2010, 09:32 AM
jeffie8696
jeffie8696's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you know what fuel you were running? And the prop. I will do some more testing in the future.
Old 05-11-2010, 01:27 PM
Lost Glider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Omega 15% and a 6x3 prop, I don't remember what brand, performance can vary greatly from one brand to another. I hope to run my engines again this season, I think I have of 16 of them now.
Old 05-11-2010, 02:06 PM
jeffie8696
jeffie8696's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Personally I would be using a fuel with a much higher oil content. Omega only contains 17% oil. Iwould be using 20% or higher in a lapped iron piston engine like these. Ihave a bottle of Sig 10% nitro 25% all castor that Ilike for these types of engines. I like a little more nitro but 10% is all Ihad at the moment.
Old 05-12-2010, 03:12 AM
Lost Glider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I added 4 ounces of castor oil to the gallon so that put the lubrication up around 19.5 percent. My Omega fuel is almost gone, then I will be using Trinity Platinum 30% nitro with 11 ounces of castor oil added per half gallon, that gives about 21.6% lubrication and 25.6% Nitro. This works out good for me because 3 gallons of fuel, can be modified with 2 quarts of castor oil, plus a few ounces more from the drugstore.
Old 05-12-2010, 10:52 AM
jeffie8696
jeffie8696's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That sounds much safer.
Contact Us Archive Advertising Cookie Policy
