Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Super Tigre S75
Old 03-22-2009, 10:25 PM
My Gallery
My Models
My Feedback
Default Super Tigre S75
I've got an older ST 75 with a 12,8 prop on it. What kind of Rpm's should I expect to get out of it? I ran it with 15% nitro fuel and I got 11,900 tuned 300 below max. Is that good? Also what kind of props would work well on this engine? It is going into a low wing 60 sized Supersport type plane.
wurstedneptune is offline
Old 03-22-2009, 11:06 PM
rainedave's Avatar
My Gallery
My Models
My Feedback
Default RE: Super Tigre S75
Theoretically, it should turn a 12x8 about the same as a sixty turns an 11x8, so 12,000 is a decent number. I have one, too, but I just put a new ring in it and I haven't run it in or taken any tach readings yet. I did notice that the ports in the sleeve seem very small. I don't know if this engine was designed more for torque/big props or for speed. I have the feeling it's not a high revving screamer. I planned on breaking in the new ring with a wood Rev Up 12x7.5
rainedave is offline
Display Modes
Contact Us Archive Advertising Cookie Policy
