Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
Webra .91 P-5 Aero (with video)
Reply
Old 08-02-2009, 09:32 AM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Webra .91 P-5 Aero (with video)
I spent a nice Saturday afternoon testing various props on my Webra .91 P-5 Aero.
I recorded the following using a Turbo-Jett muffler, 5% nitro, 18% oil and an OS #7 glow plug.
APC 14x8 10,231
APC 14x10 9,428
APC 15x6 10,302
MAS S2 15x6 10,706
APC 15x8 9,191
XOAR 15x8 9,074
APC 16x6 9,096
I think i'm going to like the #7 plugs. It gave me instant starts, a low idle and the Peak on the High needle seems much broader than when using an OS 'F' plug.
I took videos of all the prop tests and have made a compilation video and posted it on YouTube.
[youtube]http://www.youtube.com/watch?v=MuPgsD0fn3g[/youtube]
CustomPC is offline
Old 08-02-2009, 11:59 AM
PlaneKrazee
My Feedback: (14)
PlaneKrazee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Webra .91 P-5 Aero (with video)
I was getting 9000 rpm on my custom muffler 5% nitro on a APC 16X6. Good power and good fuel economy. I had one of those turbo mufflers on a 160fx. Ran great on the ground and burnt out two plugs in the air. I guess I'm no pipe guy.
PlaneKrazee is offline
Old 08-02-2009, 07:51 PM
anuthabubba
My Feedback: (102)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice. Thanks for the effort and info.
Terry in LP
anuthabubba is offline
Old 08-02-2009, 08:25 PM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: PlaneKrazee
Yeah, i've read about overheating issues with the Turbo-Jetts on the OS 1.60.
I've had a few of the Turbo-Jetts on smaller engines from .55 to .91 and they've all worked well for me.
CustomPC is offline
Old 08-02-2009, 10:35 PM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
PC, glad to someone who actually uses the P-5 like you're supposed to. Most guys try to run a 14x6 and are disappointed. I run an APC 14x12 which it turns about 8,800 on Fox 5% with 20% castor.
Hobbsy is online now
Old 08-02-2009, 11:07 PM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I haven't tried a 14x12 yet.
What airframe do you have your's mounted on? I'm planning to put mine on a Great Planes Venus II which should weigh around 8.5lb
CustomPC is offline
Old 08-09-2009, 11:32 PM
Kmot
My Feedback: (24)
Kmot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sweet! Loved the video! [sm=thumbup.gif]
Kmot is offline
Old 08-12-2009, 01:14 PM
särpet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
webra .90P5 apc 12x12 11500rpm and no nitro.
särpet is offline
Old 08-12-2009, 07:17 PM
Hobbsy
My Feedback: (101)
Hobbsy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had mine on a Cermark Sukoi 30, perfect match, I sold the Sukoi to a friend at Church so right now the P-5 is planeless. He put a Magnum or TT 1.20 on it which shook the firewall loose and crashed it.
Old 08-12-2009, 07:44 PM
PlaneKrazee
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The P5 is smooth!
Old 08-25-2009, 05:11 PM
Harry Lagman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
CustomPC, thanks for this compilation - an excellent way to document a test session. Nice work!
Looks like that Webra is a good, solid performer. Those numbers on the APC 14 x 8, 15 x 8 and 14 x 10 are not far off what I'm getting on my YS 1.10. on 20/20 fuel.
Harry Lagman is offline
Old 08-26-2009, 02:49 AM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Harry,
I had the YS in mind when i selected this engine.
The plane i was planning to put this engine in is a Great Planes Venus II and the YS is a fantastic engine for that model, although there is a general consensus that the OS 1.20AX is better, if not a little overkill.
The main issue is weight as the model is nose heavy with the 1.20AX although it has plenty of power to carry the extra weight.
The Webra with muffler comes in smack on 800gm ready for the spinner (ie. no prop nut or washer.) I believe the YS might be a touch lighter but i'm not a fan of YS's.
The goal was to have the plane lighter than it would be if the 1.20AX was used and with similar power to the YS1.10.
I think the webra is very close and should give me what i'm looking for although i'm now swaying towards the new Thunder Tiger F-130S which is identical in weight and turns the 14x10 at 9135rpm on only it's 3rd tank of 15% fuel. I think for this application (sportsmans pattern comps) the instant response of a 4-stroke might be better.
My next model will be a Kyosho 90 sized mustang and my dilema is which engine to use. Both engines would be ideal in the Mustang as well.
CustomPC is offline
Old 08-26-2009, 04:41 AM
PlaneKrazee
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Webra sips 5% fuel.
Old 08-26-2009, 08:03 PM
Harry Lagman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Custom, I am considering the same combo - a Venus II with at this stage, either a YS 1.1 or an OS AX 1.20. The AX 1.20 seems the stronger of the two but as you say, it's also heavier. I am looking at a simple to assemble "pattern style" ARF aircraft to practice IMAC routines with.
I wonder what the new AX 95 goes like compared to your Webra. As it happens, I am putting together an order for miscellaneous stuff at Tower as I type - hmmm, wonder if the missus would notice this extra item...
Old 08-26-2009, 08:23 PM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've looked at the specs for the OS .95Ax and the bore/stroke and weight are all very close to the webra so it should give comparitive performance.
I would guess that the compression on the .95AX is lower and it would need 10-15% nitro to perform as well as the webra.
On OS's japanese web site you can view their latest catalogue and they show the .95AX in the Kyosho Mustang .90 and have a list of recommened models including the Venus II.
They also suggest the FS 1.10a for the venus but IMO that would be too weak.
P.S.
I recently got a significant discount code from Tower for international customers only and specific to my email address. Perhaps you got it too, but if you didn't you should check that your details at Tower are correct.
CustomPC is offline
Old 08-26-2009, 09:37 PM
PlaneKrazee
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like the Webra's ability to swing the large props on low nitro.
Wow,
Tower is screwing it's international retailers. Why didn't they offer the local hobby shops the opportunity to sell at the reduced prices? Greed! Great Planes/Tower/Hobbico is putting local hobby shops out of business world wide.
Old 08-28-2009, 01:21 PM
estradajae
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With reviews like this...I still thinking where is the ability of the four strokes to swing bigger props??..... this engine is a ruler!
estradajae is offline
Old 08-28-2009, 04:04 PM
RVman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine turns a graupner 15-8 3 blade peaked at 7200 rpm. Unfortunately I had the prop throw a blade in the air on a full power pass, ripping the engine of the plane. Obviously it didn't fly very well with 2 lbs missing on the nose... So the engine is planeless until next year. I would like to try a 16-8 three blade and if the engine runs ok on such a large prop it would look awesome on a 60 size warbird.
RVman is offline
Old 09-17-2009, 05:18 PM
CustomPC
CustomPC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Harry Lagman
These figures for the .95AX have just been listed in another thread. The Webra beats it by 500-600rpm on 10% less nitro. Granted, the Jett muffer might have something to do with it.
ORIGINAL: mfuess
Using COOL POWER 15% Nitro, my 95AX did this:
PROP Size MFG. RPM
13 x 6 APC 12,400
13 x 8 APC 11,250
14 x 6 APC 10,800
14 x 7 APC 10,320
14 x 7 Graupner 9,630
14 x 8 APC 9,750
15 x 6 APC 9,600
CustomPC is offline
Old 09-19-2009, 09:28 PM
PlaneKrazee
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: RVman
16X8 3 blade? That's way too big!
Old 09-20-2009, 09:09 AM
RVman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I emailed the webra factory awhile back and they were running this engine down around 6000 rpm with no problems so it might work.
RVman is offline
Old 09-21-2009, 04:30 AM
PlaneKrazee
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Graupner 16X8 3b was recommeneded for the Enya VT 240, wide blades and heavy load. You will be way below the powerband, but it's fun to try! Your warbird's airspeed would also be a bit slow spinning a 8 pitch prop below 7000 rpm.
