Evolution .60NX with Jett Stream Muffler
RE: Evolution .60NX with Jett Stream Muffler
ORIGINAL: Ernie Misner
Did you make a tape recording of those beautiful sounds?
Ernie
Ernie
My Feedback: (79)
ORIGINAL: SpinnerRow
Nope, but I'll have to put my new HD camera to use tonight. That 9x10 is sick. It made me take a step back from the test stand when it went on the pipe. I can tell I'm in love with this engine already and I hope it stays together long enough to get past the honeymoon.
Ernie
Ernie
It's sad that manufactures make a decent engine and stick cheap bearings in it. What did they save 25 cents their cost? When Evolution first came out with the 46 NT, they had bearings with plastic cages, then about a year later they switch to cheap steel cage bearings. Yeah, I noticed, and I noticed the shorter bearing life too...Horizon!
CO
ORIGINAL: Iflyglow
My only concern was with the cheap steal retained rear bearing and High Rpm. I switched mine out when I was massaging the inside.
Ernie
Ernie
ORIGINAL: RC-Bearings
What size bearings ended up in your engine?
There is more bearing talk on the last two pages of this thread.
#31
My Feedback: (79)
http://www.pspec.com/details.asp?ProdID=77&category=7
Paul,
I have your 15X28X7 (6902) and .375x.875x.281 (R6-2RS) in mine. We will see how it works out.
#34
Maybe they just want to fly sport aerobatics.
Ernie
Ernie
One is on a Strega 40 turning a 10x8. This one is more speed oriented for sure but I have noise restrictions at my field and I need to keep it 15K or less. The 10x8 will put me right there (in cooler weather). The 9x10 is upper mid 15K range and I bet the 9x8 would get into the 16,500 range. But man, at close to 16K the last time I tested a 9x10, the sound was nuts. And I actually tried a 9x10 on the Strega and didn't like it. Virtually no climb out and the speed gain wasn't that great enough for me to "have to have" that prop on the plane.
#35
APC 9x9
Omega Aero 15%
94 degrees and 70% humidity
I've also cleaned the ports up on mine a bit as well as replaced the bearings.
16,400rpm
Omega Aero 15%
16,400rpm
#36
Do you mean you've cleaned up the transfer area or did you get into the ports themselves where the chrome plating is?
Ernie
Ernie
#37
Ernie
Ernie
#38
My Feedback: (81)
Guys, I have put a hole in one piston and broken the crank on the other. Both only ran about 2 minutes and both blew on throttle up. Two turns out to start and running a 10x7 prop with the Jett muffler. Spinning both of them by hand felt really tight and just felt like there was metal on metal binding inside.
Any advice?
Any advice?
#39
ORIGINAL: Dblex
Any advice?
Any advice?
#41
ORIGINAL: Dblex
So 2 turns as per the manual is too lean???? Where do you think I should start out at?
Thanks for the help guys!
By the way, an APC 10x8 is an ideal prop for this motor. I have two of them. One on a pipe and one on the Jett muffler. Very powerful motors. It loves the 10x8.
#42
CO
One other thing to think about. Running these engines much past their design RPMs will start to show any weaknesses. I would be tuning to run a larger prop at the same RPMs. You get much more pull by doing this and you keep the engine well within their operating range.
#43
ORIGINAL: Dblex
Any advice?
Any advice?
#44
ORIGINAL: Dblex
Any advice?
Any advice?
BTW - our Jackals run with the EVOM1 mini-pipe muffler at about 1-1/8 turns out from closed. That muffler tends to have a ton of muffler pressure and provides a lot of fuel to the engine so running at two turns out should have been very rich. If it is not I would look into the muffler pressure system between the muffler and the fuel tank.
Pete
#45
I can interchange an APC 12x5, 11x6 and a 10x8 and get pretty much the same RPMs. It is all about your flying style. I don't like the large diameter short pitch props - too slow.
#46
CO
I was mostly speaking to the people who are trying to get more speed from a draggy airframe. Going to smaller diameter props is counter-productive in those cases.
#47
ORIGINAL: Dblex
Any advice?
Any advice?
Is the fuel system plumed correctly, when empty, can you you blow from the carb line through the tank into the muffler without blockage?
I know the manual calls for Cool Power, but I'd like to see some castor oil as part of the fuels oil makeup especially during break-in.
When new, they do feel tight, primarily at the top of stroke. Don't turn it unnecessarily by hand.
The needle setting of two turns may be wrong when the tuned muffler is used, the setting is a starting point, not written in stone. You may need to start with more turns open to be safe.
Start it and get it up to speed temperature. Extended cold, low speed running when new could do harm.
They need to be ran-in rich with lots of smoke, wide open, about 1500-2000 rpm OFF PEAK RICH regardless of needle turn count. 10X7 should be OK for this.
The sound should be just inside the smooth two stroke scream and the engine should jump if you MOMENTARILY pinch the line. After running a few moments you should barely be able to hold your finger on the head. Run for two tanks like this and on the third tank start working it leaner, about 500 rpm off peak by the end of that tank. Go fly.
If you are not sure, get help. Don't kill another engine.
Have fun be safe & good luck.
#48
My Feedback: (81)
Actually, I was told 2 turns out to start is too rich for this set up. To start at 1.5 turns and that this motor/pipe Combo likes it leaned in around 1 and 1/8th turns. The 2 turns out apparently was flooding the motor and causing a backfire. The Jett apparently kicks out alot of muffler pressure wich I was told can flood this motor. This was from a Rep that I spoke with at Horizon.
#49
My Feedback: (81)
I just cant figure this out...
My Jett muffler doesnt seem to be getting enough pressure to tank as my motor gets super hott and loads up, but when I put the stock muffler, she runs smooth and cool....
What are your guys needles at on the high end??????????????? Im curious!!!!!!!
