Tomy Model MT35 gasser
My Feedback: (14)
Weather: 100% humidity, temp 46 degrees. Stock exhaust. The engine has about 3/4 gallon thru it now.
APC18X6W 8300
APC 19x8W 7250
Bolly Carbon 18x10 8000
Bolly 16.5x10 3 blade 7700
Mejzlik 19x8 7400
Mejzlik 20x6 8000
Mejzlik 20x8 7000
Vess 19A 7630
Based on the rpm of the APC 18x6W this engine is not a revver but a puller.
APC18X6W 8300
APC 19x8W 7250
Mejzlik 19x8 7400
Mejzlik 20x6 8000
Mejzlik 20x8 7000
Vess 19A 7630
RE: Tomy Model MT35 gasser
Good values.I thought that MT 35 turns a little faster.Actually I am surprised that my Super Tigre ST 3250 converted to gas performs better with Menz S 18x10 at 8200,Menz S 19x8 at 7800 rpm,Menz S 20X9 7000 rpm.200cc volume canister muffler.Menz S are hi-load propellers.The engine is also a torquer,does not like revving over 8000 rpm.
I am curious after 2-3 gallons what numbers would you have.
Two questionsid you mesured the temperature?
How looks like vibration level?
My Feedback: (14)
The vibration seems low. The rpm may increase if I change oil. I added one oz of castor to a gallon of mix and got more rpm out of the DLE30.
I need to remount the MT35 and DLE30 to compare vibration levels more accurately.
After 1 hour running time,try Motul 800 35:1 mix and keep this ratio.You will have a very long-lasting engine doing so.
What about Temperature?(Celsius...)
My converted stays around 125 celsius WOT 2 minutes with 20X9,12:1 mix (because of bronze bushing)
Vibrates a little stronger on gas,but not so strong.
