Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
RPM Reading - 2 vs 3 blade
Reply
Old 07-12-2010, 08:53 PM
T-ster
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RPM Reading - 2 vs 3 blade
I have an old tach and the labels have long since fallen off. When I'm checking the rpm, I'm not sure if I have it in the 2 or 3 blade mode (it has a switch than slides left and right). When I switch between the two settings, should the higher of the two numbers be in 2 or 3 blade mode?
Thanks.
T-ster is offline
Old 07-12-2010, 10:10 PM
krayzc-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: RPM Reading - 2 vs 3 blade
2 is higher
krayzc-RCU is offline
Old 07-28-2010, 09:34 PM
RVman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Point the tach at fluorescent light. It should read 2400RPM for 3 blade and 3600 for the 2 blade setting.
RVman is offline
Reply
Display Modes
