Tachometer Readings Post your tachometer readings for your motor in here or ask others what they are getting out of their motor/prop combos!
ASP/MAGNUM 180FS readings
Reply
Old 08-12-2010, 07:38 AM
benjret
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default ASP/MAGNUM 180FS readings
Anyone got some numbers for the ASP/MAGNUM 180FS?
ASP 180FS. OS F Plug. Byron 5% nitro, 16% Syn+2% castor
APC 16x8 @8900rpm Max
MA 16x8 @9400prm Max
APC 16x10 @8200rpm Max
MA 18x6 @8400rpm Max
Hawk Wood 18x8 @8200rpm Max
anyone got some number with 17x8?
Thanks...
benjret is offline
Old 08-13-2010, 07:09 PM
Gregor32
Gregor32's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ASP/MAGNUM 180FS readings
Hi there is lots of info here http://www.rcuniverse.com/forum/m_4720370/tm.htm
Greg.
Gregor32 is offline
Old 08-16-2010, 10:52 PM
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
""anyone got some number with 17x8""
Magnum 180 4st; APC 17X8 burning Magnum 15%/ 8100 tuned for flight,,
if you can get it I would sugest to move up to 10% or 15% (even 20%), I ran 5% for a few Tanks for the "Brake-In" and it runs much smoother on 10 and 15%..
Jim
the Wasp is offline
Old 08-18-2010, 03:19 PM
benjret
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: the Wasp
Jim
Thanks jim..
benjret is offline
Old 08-18-2010, 03:21 PM
benjret
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Gregor32
Greg.
Thanks for your information Gregor32
benjret is offline
Old 08-18-2010, 03:38 PM
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
benjret ,, here is some more info for you,
I went flying yesterday, so I mixed up some Magnum 15% with Magnum 30% Heli Fuel, added 2oz of Castor, my numbers tell me it's about 20% and it Tach'ed out at 8600 with that APC 17X8
Jim
the Wasp is offline
Old 08-19-2010, 05:36 PM
benjret
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: the Wasp
Jim
Wow.. Thanks Jim! i appreciated.
i think im gonna try with 30% Nitro to get more rpm.
benjret is offline
Old 12-28-2010, 08:09 PM
wrob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
APC 16x8
PowerMaster 15% nitro, 18% oil
3,100 ft elevation
9,200 peak
wrob is offline
Old 08-01-2011, 10:38 PM
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow RPM update
Magnum 180 fs,, 1 Head Shim, Wild Cat 15% Nito, 16% oil, same APC 17x8w, 8850 RPM tuned for flight,,
I have to say I was surprised to find this number after I removed one of the Head Shims,, but I also have to say that the APC 17x8w IS the wrong prop for tight acrobatics, it takes to long to Rev-up, I think an 18x6 or 18x7 quality wood Prop would pull much better around half throttle
I'll let you know
Jim
the Wasp is offline
Old 08-05-2011, 11:37 PM
MetallicaJunkie
MetallicaJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just curious i thought the 16x8 was the 150 prop of choice.... i guess as long as the rps are under 9500 its all good
MetallicaJunkie is offline
Old 08-13-2011, 08:01 PM
the Wasp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
""just curious i thought the 16x8 was the 150 prop of choice""
Junkie,, first, this is a 180 not a 150,,
2nd, the APC 17x8w is ok for acrobatics on the 180 when you don't need a quick Rev Up, I did some tight loops/almost a flip, but the Engine would not Rev Up quick enough to pull the plane up into another tight loop,, a lighter Wood Prop with a larger Diameter/Less Pitch would Rev high yet because of the larger Diameter it should pull more Thrust at half Throttle
yet, for a War Bird the APC 17x8w would be better than the larger Prop with less Pitch..
Jim
the Wasp is offline
Contact Us Archive Advertising Cookie Policy
