Cyclon JAK 09 combat glow
Tacho'ed a friends Cyclon 09 glow today, 24300 on an F2D combat prop, 10% nitro on suction.
It flew OK in stunts on this venturi, could probably go bigger for level flight, definitely would be faster on a bladder ! |
RE: Cyclon JAK 09 combat glow
how would a bladder be faster? Are the venturi's removable?
1 Attachment(s)
ORIGINAL: airraptor how would a bladder be faster? Are the venturi's removable? yes, thats right. The venturi is a push fit in the crankcase, locked in position by the spraybar. When running a bladder you can use a much bigger venturi, more air/more fuel/more power ! Up to a point, anyway |
