Webra Bully (35cc)
Old "new" Webra Bully converted to gas.
Silencer: DA 50 canister on a 22cm long header. Ignition: RCexl with an unregulated A123 pack. Fuel: 2% unleaded. Temp: 10-15°C. Propeller: APC 18x10 "sport" Maximum 7800, with a steady idle of 15-1600rpm, after warm-up. I´m considering trying an APC 16x12 or 14 since the engine is going into an enlarged Hots, and I don´t have much clearence when running 18in props. |
RE: Webra Bully (35cc)
Very intersting! Do you have a photo and is that a profile plane you are putting it on?
thanks, Ernie |
1 Attachment(s)
Hi Ernie...
The Hots hasn´t been built yet, as the "kit" is being lasercut by a friend. I hope to have the parts soon though. It´s a 160% enlargement of the original "The Hots", but modified to have a removable wing, clipped at 180cm (70,9in), and a cowl which makes it quite a bit more sporty. So for now I only have a screen shot of the plans and a 3D rendering of the finished model to show you. Specs are: Span: 180cm (70,9in) Length: 142cm (55,9in) Wing area: 70,6dm² (1094in²) Weight (est): 6kg (13,2lb) |
Ohhhh man, is that ever cool!!!!! Thanks loads,
Ernie |
Tinus,
Will you be posting more on this build. I have a several Bully engines and an 81" wing Hots. I am very interested in what youre doing. Regards Thomas |
I posted build pictures in John´s thread beginning at post #65.
http://www.rcuniverse.com/forum/m_96..._3/key_/tm.htm |
