Model name confusion
My Feedback: (9)
NC
Hello
I have the TTX 650 and it works great, but I assigned a name for the plane but it does not show up on the main screen when the model is selected. When I call up the model name it is there? Shouldn't it show up when I select the acft?
Bill
Bill
When you go into the Model Setup screen, and then the Model Management function, you are able to set the name of the model. After you have entered the name, you just press the "ESC" button to exit. The model name should show up in the upper, left-hand corner of the main screen, next to the number of the memory slot the model info is stored in. If you enter the model name, press "ESC" and the name is not saved, then your transmitter has an internal problem storing the model name, and it should be sent in to the service center.
