TTX850 Question
MI
TTX850 Question
I am considering buying one of these transmitters from a club member that has only used it a couple of time. It looks brand new!!! I want to make sure that he doesn't have any "special" setting that he has input himself. Is there anyway to reset the entire system back to factory settings?
Thank you,
Thank you,
Yes, go to Model Management and highlight "Reset" then hit "Enter"
Another neat trick you can use is, when you get that first plane set up, do the "copy routine" to the next one you want to use and all the settings will be the same as you have programmed into your first program. This is especially helpful it you have programmed in a lot of dual rates, expo, etc. as the program will be there for your new bird, you may have to change servo direction but all else will be already done for you. Also, remember to have your throttle reversed if you are programing for electric powered planes as all the ESC's that I know of require the throttle to be reversed on Tactic and Futaba systems.
Please realize that if you are not a Tactic support representative, you are not permitted to answer questions in this support forum, nor in any other manufacturer's support forums. Only the reps from the respective manufacturers have that privilege. We'll allow this particular one to stand because it's correct, but will delete others in the future. We check these forums at least once per day.
Support forums are also not discussion forums.
Thank you.
Thank you.
