urgent help needed - stampede
Can someone tell me the size of the set screw of spur gear in a stampede motor.
It appears to be 1.5mm while mine looks already rounds off, just need confirm.
Also, in case it rounds off, how to pull the gear off the motor shaft?
RE: urgent help needed - stampede
my stampede is old brushed 2WD version, now the motor has problem.
it seems rotor inside the motor is spining, while I can hold the shaft still (no spinning) by force.
is that because the shaft and rotor are detached to each other? but i need to take off the gear first to see the motor.
thx
thx
Is the picture of the part you mean? If so, that's a pinion, not a spur. I can't be sure the size on that truck as I have not owned one, but as for getting out, the best thing to do is drill it out very carefully with a 1mm bit.
IL
Next time you post a question about your traxxas stampede, please post it in either of the below sections. This is the Tamiya section, not traxxas.
[link=http://www.rcuniverse.com/forum/forumid_147/tt.htm]Electric offroad[/link]
[link=http://www.rcuniverse.com/forum/forumid_251/tt.htm]Traxxas monster trucks[/link]
