Tamiya Monster Trucks Discuss classics all Tamiya Monster trucks from the Clodbuster to the TXT1 and everything in between!
Tamiya toyota tundra Highlift 4x4 kit question
Reply
Old 07-15-2011, 01:37 PM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Tamiya toyota tundra Highlift 4x4 kit question
I recently started to try and map out my new project. Wanted to build a 6x6 Flat bed tow truck for my 1/10 on road cars. So my first thought was to get a Tamiya kit 58415 which is the Tundra Highlift and buy a extra rear axle. What would my next move be when trying to connect the 3rd axle on the extended chassis?
17dean is offline
Old 07-16-2011, 03:57 AM
The Mad Modder
The Mad Modder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Tamiya toyota tundra Highlift 4x4 kit question
Quote:
ORIGINAL: 17dean
Well, when people make 6x6 vehicles based on the tlt-1 axles, they usually get two sets of axle cases and bolt 2 of the sides with input shaft holes together to make middle axles. I think it should work with high lift axles, too.
If you use 1.7 or 1.55 size tires, you could probably use the rear tandem axle suspension from a Tamiya semi truck. Only problem 1.7 is that nobody(as far as I know) makes front drive wheels for those(Tamiya semis have bearing in front wheel design).
The Mad Modder is offline
Old 07-16-2011, 12:12 PM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Then again I was wondering if doing this same project but with a E Maxx with the extended chassis. In your opinion , which would be the easier build being this will be my first outside on road cars?
17dean is offline
Old 07-16-2011, 01:14 PM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mad Modder , what is the thing that is holding the 3rd axle and trannie in place on your traxxas sledge hammer?
17dean is offline
Old 07-17-2011, 11:19 AM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 17dean
On the first axle, the bottom of the trans is screwed to a skid plate connected to the bottom of the chassis. The aluminum plates on the side of the trans screw to the back of the chassis. To adapt the second axle, I made an extended skid plate to connect to the bottom the the 2nd trans as well. There are two cross members connecting the rear of the first trans to the front of the second for more support.
Old 07-17-2011, 11:26 AM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 17dean
It would probably be easier to extend a high lift. I think you can bolt together two input sides of an axle case to make a axle that allows the power to go into the middle axle and out into the rear axle. I'm not sure how you'd do that on a e-maxx.
Are you going for a scale appearance ? Also, does it have to be able to drive offroad?
I ask the second question because the easiest truck to convert to a wrecker would be one of Tamiya's tractor trucks. Those, however aren't very well suited for offroad driving and are only rear wheel drive(2 or 4 wheel).
Old 07-17-2011, 12:33 PM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will be mainly for on road purposes.  I mainly drive 1/10  on road cars anyway  and wanted a wrecker to have my show and race cars on when going to the track or for general bashing times. I want the wrecker as close to  1/10 scale as possible.
17dean is offline
Old 07-17-2011, 01:08 PM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just finished reading and comparing and needed to know the answers to 2 questions  Mad Modder. #1  Is it possible to run the High lift brushless and #2 can I extend the back wheel to strech it out  and do a 4x4 flat bed instead?
17dean is offline
Old 07-17-2011, 01:10 PM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 17dean
The Tamiya tractor trucks are 1/14 scale, so they'd look a bit small next to a 1/10 car. Does it have to have two rear axles? I see a lot of single rear axle rollback wreckers on the road. It shouldn't be too hard to mount a flat bed on an extended high lift chassis.
http://www.tamiyausa.com/articles/fe...article-id=280
You could do a Tundra rollback. Plus it'd be 4wd, so you'd still be able to go offroad.
RC4wd even makes duallies for 1.9 wheels.
http://store.rc4wd.com/Double-Troubl...ls_p_1214.html
Old 07-17-2011, 01:11 PM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LOL
Missed your post.
Old 07-17-2011, 01:19 PM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is settled.It shall be the Ford F350 highlift.  But how and what do I do to extend the back axle? Oh yeah , thanks a great deal for all the info and help. I was about to start saving for a Worminator before I decided to try something on my own! The 350 is right up my alley  and extremely doable!
17dean is offline
Old 07-17-2011, 01:45 PM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 17dean
Probably the cheapest and easiest way would be to get another set of high lift frame rails. Cut them to the length you want to extend your frame. Cut the existing frame rails in between the the rear axle and where the trans mounts where it won't interfere with anything. Splice the extensions into the chassis by sandwiching each joint with metal plates and bolt them together. You'll also need a longer rear drive shaft.
RC4wd and MIP make driveshafts of various lengths. You may be able to get ones made for the ax10 to work.
Old 07-17-2011, 01:58 PM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Last question Mad Modder. What can I do to give the F350 a bit more speed? Is brushless the way to go for this vehicle?
17dean is offline
Old 07-17-2011, 05:59 PM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe a very mild brushless system(like maybe a quick crawler system). Hard plastic bodies and high speed don't mix.
Old 07-18-2011, 07:53 AM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not too much speed because i will be having the precious cargo! But I do want brushless to cut down on cleaning the engine and all. So what do you recomend? Your knowledge is greatly appreciated!!
17dean is offline
Old 07-18-2011, 11:43 AM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Stock, the top speed is about 9mph. How fast would you want it to top out at?
Old 07-18-2011, 03:26 PM
17dean
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just a lil bit faster. The car it carries is the fast one! But seriously , just a lil bit more speed than 9 mph is needed. It will definately wont be a shelf Queen.  With what you know of that truck chassis , what is the max extension that can be applied? For instance , I was thinking 2.5 inches. Is that too much extra length?
17dean is offline
Old 07-18-2011, 05:47 PM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 17dean
Most rollbacks I've seen have the rear axle a bit behind the halfway point of the deck, so you'd probably want to mock it up first to see how far it needs to be stretched. That way you know that you have a long enough wheelbase for a deck you can be sure will hold your car.
Really, even a 6 inch stretch shouldn't be a problem as long as it's properly strengthened with cross-members.
Reply
Display Modes
