Tamiya Monster Trucks Discuss classics all Tamiya Monster trucks from the Clodbuster to the TXT1 and everything in between!
TAMIYA TNX 3.0 help
Reply
Old 07-20-2011, 11:07 AM
scott321
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default TAMIYA TNX 3.0 help
I have just brought a second hand TNX 3.0 and after inspection i discovered that 2 allen/hex screws in the heat sink have rounded, do any of you have any tips how to remove them without taking it to my local RC shop? any help would be most welcome.....thanks
scott321 is offline
Old 07-21-2011, 04:15 AM
The Mad Modder
The Mad Modder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: TAMIYA TNX 3.0 help
Quote:
ORIGINAL: scott321
I have just brought a second hand TNX 3.0 and after inspection i discovered that 2 allen/hex screws in the heat sink have rounded, do any of you have any tips how to remove them without taking it to my local RC shop? any help would be most welcome.....thanks[img][/img]
I've heard you can sometimes get a rounded hex screw out by putting a piece of thin plastic (like saran wrap) over the tip of the driver. It makes it a little tighter of a fit in the hex socket.
The Mad Modder is offline
Old 07-21-2011, 11:22 AM
scott321
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thank you very much........i'll let you know if it works.
scott321 is offline
Old 12-03-2011, 04:13 PM
tamiya08
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine were like this, I just sprayed with them PB blaster, then Covered all the holes on the engine and drilled the head of the screw off.. Once the head of the screw was off, the rest of the screw turned with pliers and I was able to get the screw off
tamiya08 is offline
Reply
Display Modes
