Tamiya Monster Trucks Discuss classics all Tamiya Monster trucks from the Clodbuster to the TXT1 and everything in between!
shock set-up
Reply
Old 12-09-2011, 09:44 PM
detroiteddy13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default shock set-up
Hey what's up? Just wondering the best shock set-up for clodzilla 2 chassis. I jump this truck off everything and do not like the set-up on it now, which is shocks mounted on stand-offs from frame and angled plates on the axle stays. Doesn't seem to have even geometry and binds on articulation pretty bad even with shimming. Any ideas are greatly appreciated.....Thanks
detroiteddy13 is offline
Old 12-10-2011, 07:02 AM
The Mad Modder
The Mad Modder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: shock set-up
Quote:
ORIGINAL: detroiteddy13
So the binding is only there with the shocks attached? If you aren't already, try using just 4 shocks. Most of the weight of the clod is unsprung weight(weight that isn't on the shocks), so using 8 shocks is overkill anyway.
The Mad Modder is offline
Old 12-11-2011, 10:42 AM
detroiteddy13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i only have four on it. it seems like it's the mounting brackets that are off, any recomendations for lower mounts that work good, thinking about just using the mounts that clamp on the links. thanks
Old 12-11-2011, 04:50 PM
The Mad Modder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What shocks are you using? Do they have pivot balls on the bottoms or connect to ball studs?
If they just use regular eyelets riding on bushings, that may be your problem.
Old 12-14-2011, 07:43 PM
detroiteddy13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
just the shock eye with ball. i think i am going to go with clamp type mounts directly on the links so that they are even with the chassis. i will let you know how it works out when i do. thanks
Reply
Display Modes
