Tamiya TNX 5.2r
RE: Tamiya TNX 5.2r
I AM IN ABIT OF TROUBLE AND WAS WONDERING IF ANY BODY WILL BE HAPPY TO HELP.... as i am a owner of a tamiya tnx 5.2r and my engine has blown which engine will be sutiable to replace the old engine....? can you please sent a a sutiable engine on ebay auction which i could purchase.
can i replace the engine with any engine sizing from .28 / .21 even though my orignal engine size is .32
model : tamiya tnx 5.2r
engine : 5.2cc / .32
would be great full for the help thank you
RE: Tamiya TNX 5.2r
IL
RE: Tamiya TNX 5.2r
Hi im in need of HELP...iv recently purchased a brand new fr.32fx engine for my tamiya tnx 5.2r and replaced the old engine which was not working. but theres a problem the new engine wont fire up the roto start just keep spinning ...any chance anybody can help..?
IL
RE: Tamiya TNX 5.2r
ORIGINAL: tamiyatnx786
#32
RE: Tamiya TNX 5.2r
HELP! My handy starter has given up the ghost and it would appear that tamiya have stopped making them as no one has any in stock if any one has one i that they would be willing to sell please could you get in contact.
Thanks.
#33
IL
RE: Tamiya TNX 5.2r
Are you talking about the starter tool or the gear units?
http://www.tamiyausa.com/product/ite...oduct-id=41075
http://www.tamiyausa.com/product/ite...oduct-id=41077
http://www.tamiyausa.com/product/ite...oduct-id=41076
#34
RE: Tamiya TNX 5.2r
Thank you so much for finding this, the starter tool is the part i need, however $167 is a rediculouse price considering the original value for this part was around $60 and ive seen so advertised at about $40, further more i have had numerouse problems with websites claiming it is in stock when it is'nt, i will look into it however even if it is in stock im not sure i'd be willing to pay that much.
Thanks again,
Will.
Thanks again,
Will.
#36
My Feedback: (10)
RE: Tamiya TNX 5.2r
I would just put a pull starter on it. I have had rotor start before and been through many one-way bearings.
It is not hard to pull start a bigger motor. A lot of times, a lil bit of nitro into the carb and then it will start with one pull
#38
Getting frustrated. seriously need help.
Help needed.
I am not new to rc nitro engines but with my knowledge I am still unable to get my tamiya tnx 5.2r started. I have checked the glow plug and its good. The engine is not flooded and the air filter is clean. The carb is clean and feeding fuel as I crank tje engine. I have disassembled the engine and everything inside is in good condition as the engine has less than 10 running hours. When I crank it it would start one in about 100 tries but then cuts shortly after. I first thought that my fuel mixture is too llean or not lean enough. I also think that my carb my not be mixing air to fuel correctly. Could it be the idle screw for any reason or the distance of the fuel feed valve in the carb?? If these could be the reasons how could I go about fixing it?? If anyone has any other suggestions as to what is wrong let me know.
#39
Check out a nitro engine forum, this one is dead.
find out what stock settings are, change the glowplug and lines and give that a try. That motor might be poop though.
