Team Associated - Monster GT Discuss all things AE MGT right here!
brushless mgt
Old 04-05-2011, 08:27 PM
myposrustler
Default brushless mgt
well i thought i would share this i sure there are alot of these out there but i got tired of buying nitro its not cheap here lol so i got a novak hv pro 6.5 brushless setup and a motor mount from tekno started putting this togeather about a week ago ran with the 2 speed for a while till the owb took a crap. so i locked the trans in 2nd gear and locked the 2nd gear to the main shaft here are some pix
i started with this mount i made didnt really like it
then went to this with the novak hv the mmm was for my ofna hyper st pro
Old 04-05-2011, 08:29 PM
myposrustler
Default RE: brushless mgt
lol love the masking tape on the wires there is now shrink wrap on them that was just to mock up the wires i dont like long wires everywhere
Old 04-06-2011, 12:29 AM
myposrustler
well if any one has done a bl conversion on one of these and used the stock trans id like to know what gearing you used right now i got 11t/54 i know it could use bigger pinon but mod1's are almost 10$ so any help would be nice on that thanx
Old 04-06-2011, 01:30 AM
Sibant
im using a 18t pinion but my truck is cogging like a ***** when i try to launch or anything more then 1/4 throttle
how fast is your truck with the 11t?
Old 04-06-2011, 04:42 PM
myposrustler
well i have the novak hv 6.5 and it it sensord so i dont have cogging,the motor is i think 3400kv with a radar gun ive had it up to 42mph that was with the 11t and 54t the motor stays really cool after a 30min run its only 90deg esc is around 72deg what motor do you run and what are the temps you get with the 18t i do have a mamba monster motor and esc but i like the sencored stuff
Old 04-06-2011, 05:22 PM
Sibant
im using a hk 150a esc and a tacon 2000kv
dunno about temps cause i really cant run the truck with the cogging. i have to push the truck to get it going then if i use more then 1/4 throttle it cogs again lol
waiting for a program card but its been out of stock for about a month now
Old 04-06-2011, 08:59 PM
myposrustler
wow my buddy runs the tacon motor and its really nice works good well i guess im going to try to buy a few mod1 pinons and see how it go's the ez run you got can you program it right at the esc useing the butten or the remote my mmm cogs alot when the timeing and start power is turned way up
Old 04-07-2011, 12:04 PM
Sibant
for some reason they only let you program this hobbyking 150a esc with the prgram card and its out of stock lol
its driving me mad
Old 04-07-2011, 11:19 PM
myposrustler
got a new body for it as for the settings it should come out of box with punch disabled meaning it gives as much power as the batts can handle what are you running for batteries if lipos what c rating and how many cells
Old 04-07-2011, 11:31 PM
myposrustler
here is some info i found i guess there is a number of things that could cause the cogging are you running 2.4ghz or am tx rx? http://www.rcuniverse.com/forum/m_9745051/printable.htm hope this helps might not be the programing does it do it when you have the truck off the ground?
Old 04-08-2011, 11:30 AM
Sibant
using 2.4ghz radio and a 6s lipo 30c 4000mah and no it dosnt do it when i lift the truck off the ground
Old 04-09-2011, 02:12 PM
ilanstylz
My Feedback: (12)
Nice setup, yeah theres alot of parts that I need that are out of stock as well, but I did find this for you:
http://www.hobbypartz.com/hobbywing-...ogram-box.html
I'll be getting one soon as well....
Old 04-09-2011, 09:56 PM
Sibant
i have that exact programmer but the hobbyking 150a esc has a special box made just for it and its been sold out for about a month now
this one here   http://www.hobbyking.com/hobbyking/s...dProduct=10458
i cant run the truck anyways cause my lipo charger burst into flames charging my 6s lol
Old 04-10-2011, 08:19 AM
ilanstylz
My Feedback: (12)
ORIGINAL: Sibant
***, I've heard of lipo's catching fire, but never the charger..... What brand charger was it? Man don't tell me they need heat sensors on chargers now lol.....
Old 04-10-2011, 10:58 AM
Sibant
was a supermate dc6. started smoking and the lights started to blink then FIRE!!!!! lol
Old 04-17-2011, 10:14 AM
myposrustler
well i just got my 8.0 tranny in. the 4.6 tranny went through 4 2speed gears in 3 packs lol so this 8.0 is all steel gear and bigger shafts
Old 04-17-2011, 04:06 PM
Sibant
very nice!!!
i figured out my problem. my setup isnt cogging its not getting enough power!!
my motor is squeeling cause it dosnt have enough juice off the launch or at full speed so i really think if i get the esc programmer it will run great
have you run it much with the 8.0 tranny?
Old 04-18-2011, 02:18 PM
myposrustler
not enuff power how are you batts what are you running. and yes the 8.0 tranny is sweet all steel gears im running the 2 speed till the one way bearing goes out then ill lock it like i did with the 4.6 trans also i just got a savage 25 ss i made that brushless with a mmm 2200kv system thatts fun too but the mgt will out run it on a track the only monster truclk i think comes close to handling like the mgt is the losi or well the revo but that is more like a truggy to me
Old 04-19-2011, 03:04 AM
Sibant
im using a 6s 4000mah
i cant change setting for timing and punch control yet but i really hope that fixes my problem
stupid hk taking over 2 months to stock a damn program card
Old 04-23-2011, 09:54 PM
cummins driver
My Feedback: (31)
cummins driver's Avatar
Looks good. What wheels and tires are those in the 2nd picture?
I have a brushless monster GT. Im running the HK 150a ESC and an EZrun 2350kv 3674 motor in it. However, Im also running an HPI E-Savage transmission instead of the monster GT transmission. Works great. I have been running it for around a year now and have had very little problem out of it.
Eric
Old 04-25-2011, 09:27 AM
Sibant
do you have the program card for the hk 150a?
ill send you my right nut if you can let me use it. hk been out of stock for over 2 months now and no sign of em commin in soon
Old 04-28-2011, 01:03 PM
Sibant
well some progress has been made
the hk esc is same as a ztw esc so im tryin to get a program card for a ztw but they look to be sold out everywere as well
found a few people who own a hk card but either they dont respond or arnt willing to let me use it
Old 05-03-2011, 12:38 AM
Sibant
hey cummins if you get a minute please check your inbox
Old 05-03-2011, 08:17 PM
Sibant
ohhhhh yeah! hk just got some esc and cards in!! the e-mgt shall rise again
Old 05-11-2011, 02:38 PM
Sibant
well got my program card and motor still dosnt run right
i have to ease into throttle to get it to move.. if i try and give it say 1/4 throttle out of the hole the motor squeals like a drill when you dont pull the trigger enough
if im goin a decent speed and try to give it more then 3/4 throttle the motor dies
anyone have any idea what this could be?
